67 rallyes & tire. Will they fit - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 29th, 03, 12:06 PM Thread Starter
Right now on my 67. I have P255/70R15 on the rear. They are on centerline wheels with 3.5 back spacing. They rub on the outer wheel well. Would like to go with a Rally. 15x8 with 4.25 or 4.5 bs Do you think this tire would clear everything or still rub the wheel well? Inside I think would be ok
Thanks.....Ron
Fast67 is offline
post #2 of 4 (permalink) Old Jul 30th, 03, 12:57 AM
You will be better off with the 4.5" bs. There should be plenty of space inside. Some are running 5" bs with no problems. I run 245/60/15's on 4" bs and get the same occassional rub under load. The 255/70/15 is a taller tire which should not cause any problems. Good luck.
Mike67RS is offline
post #3 of 4 (permalink) Old Jul 31st, 03, 04:50 PM
if stock rearend
i used 15x8 5inch backspace wheel vintiques
with 245/60r15
4.5 back space should be ok too for the 70 series [img]graemlins/beers.gif[/img]
I sold my Camaro,hope the current owner drives it.
Email
I live near Albany,NY USA,
where are You?
cavemanmoron is offline
post #4 of 4 (permalink) Old Jul 31st, 03, 05:09 PM Thread Starter
Thanks guys. I will be using Wheel Vintiques 15x8 4.5 BS So I guess I will order them now
Thanks guys.
Ron
67 Camaro SS/RS 454/450HP Autogear M22 4.10s
Fast67 is offline
