Help with tire size - Team Camaro Tech
post #1 of 1 (permalink) Old Aug 24th, 03, 03:09 PM Thread Starter
I have a 67 convertible that came with 14 inch, 26.8" OD tires. I want to go with 15" 60 or 70 series on the front and maybe 60 or 50 series on the rear. Should I stay around the same OD size and can I go with 60 or 70 series on the front without a clearance problem? What rim offset should I use so the tires stick out in the wheel wells the same distance?
Ohio67 is offline
