Will 18 x 8's w/ 5.75" BS fit??? - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 5th, 03, 07:17 AM Thread Starter
V8
Will 18 x 8's w/ 5.75" BS fit a 67 F-body w/ Baer disc brakes and thats dropped 2-3 inches??
I know most recommend about a 5" BS w/ 18x8's.
Thanks, Chris
V8 is offline
post #2 of 2 (permalink) Old Sep 5th, 03, 07:36 AM
Jody
camcojb's Avatar
Front or rear? On the front it'll probably rub pretty good on the inside; 5" is about all you want up there unless you have an aftermarket subframe. On the rear it'll work but you may need 1/4" spacers as it will also rub on the inner wheelwell, especially when turning corners and hitting driveways at an angle.
Jody
camcojb is offline
