Corvette wheels on 69Z - Team Camaro Tech
post #1 of 14 (permalink) Old Sep 15th, 03, 08:24 PM Thread Starter
Am wondering if 15 x 8 Corvette wheels will fit on front of a 69 Z. Have P235 60 15 BFG TA's for them.
I saw a set on a 67 RS/SS , LOOKED VERY NICE! But realize there is more room on a 67 than on 69. May be a rub when turning???
Just wanted to ask you knowledgable dudes!
69 Z / X-33 - building a 302<br />M-22 - Needs 12 Bolt -
Hugger69 is offline
post #2 of 14 (permalink) Old Sep 17th, 03, 04:11 PM
Angry
I'm not sure if those wheels will work or not. I took the front wheels and tires off my 71 Vette and put them on the 67 Camaro.They are 15x8 with 235's on them. It was quite a tight fit. Don't think I would have been able to turn the Camaro. Not sure what the backspacing is on the wheels.Hope this helps.
67camss/rs is offline
post #3 of 14 (permalink) Old Sep 21st, 03, 03:15 PM
I used that set up on my 69 rs\ss. They will rub on the front fender wells.I just bought a set of 15x7 ss wheels and I am going with 225\60 on front, and 235\60 on the rear. I also didnt like the look of the wider tire\wheel on the front, of course that is just a matter of what you like. I dont know if a smaller size tire on the 15x8 would still rub, but I know the 235's will. Hope this info helps.
yogi is offline
post #4 of 14 (permalink) Old Sep 21st, 03, 03:19 PM
I assumed that when you say corvette wheels, you are talking about rally wheels. That is the wheel I am refering to. I don't want to mislead you with bad info. Good luck.
yogi is offline
post #5 of 14 (permalink) Old Sep 23rd, 03, 05:41 PM Thread Starter
Yes, corvette rally wheels is what I'm wondering about. 15 X 8.
Hugger69 is offline
post #6 of 14 (permalink) Old Sep 25th, 03, 06:48 AM
You really need the aftermarket 15 x 8 ralley with the extra 1/2" backspacing for the front. I had them and 235/60-15 on my '69 and it was lowered 1 1/2" also. They fit and looked good. I have 17" wheels on it now.
Gary
Gary M.<br />'69 Camaro<br />Red Pro-touring<br />383 ci 440 hp
Gary M. is offline
post #7 of 14 (permalink) Old Sep 30th, 03, 08:21 AM
Mike H
15x8 corvette wheels have the wrong backspacing. I tried 15x8 w/4.5" backspacing from NPD up front and it still rubbed. I would recommend 15x7 max up front on a '69...
i put the 15x8's out back.
btw, i have 15x7 235/15 up front- 15x8 245/15 out back..
My '69:
mr69 is offline
post #8 of 14 (permalink) Old Sep 30th, 03, 09:46 AM
MStennes's Avatar
Gary,
What size 17's are you running? Backspace too?
Thanks,
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
MStennes is offline
post #9 of 14 (permalink) Old Oct 1st, 03, 05:40 AM
Mike,
I have a set of the ZR1 style 17 x 9 wheels from a '98 SS Camaro that I got for $600. They have 7" backspacing. I use a 2" adapter front and and 2 1/4" rear from Vette Products & Brakes. Tires front 255/40-17 rear 275/40-17. Car is lowered 2".
Gary
Gary M. is offline
post #10 of 14 (permalink) Old Oct 1st, 03, 09:04 AM
I had a set of 15 X 8" Corvette Rally wheels on a 69 SS I owned years ago. They had the stock tires on them which I believe were G70-15's (I think that equates to 225-70-15). Those fit fine except if you turned the steering wheel all the way in either direction the front of the tires would just barely touch the subframe. I lived with it cause I loved the way the 8 inchers looked on the front!!!!!
dougrmac is offline
post #11 of 14 (permalink) Old Oct 1st, 03, 11:06 AM
Conrad
No fit issues reagrding using the corvette 15x8's on the rear?
69rad
69 350 4spd. Convertible **FOR SALE**
Cowl Inducted LT-1 with full Instrumentation
69 X77D80
Fathom/Black
69rad is offline
post #12 of 14 (permalink) Old Oct 2nd, 03, 10:41 AM
No problems at all with the stock 12 bolt and drum brakes.
dougrmac is offline
post #13 of 14 (permalink) Old Oct 3rd, 03, 04:40 PM
On my 69Z with factory 15x8 rallys and P255x60x15 tires I had rubbing on outer fender lip. Factory 15x8 wheels are 4 inch backspacing. I went to 4.5 inch backspacing rallys from wheel vintiques, problem solved. In the front I have the stock 15x7 rally with P35x60x15, P245x60x15 might work also. This is a great looking wheel and tire combo. I especially like the look of the deeper wheels in back. Factory vette trim rings fit these aftermarket wheels also.
Chucky is offline
post #14 of 14 (permalink) Old Oct 4th, 03, 02:10 AM
chucky,
Any pics of your combo?
thanks
Kelvin
1969 RS Z/28<br />1969 X-22 RS/SS
X-22 Pilot is offline
