backspacing & tiresize questions - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 24th, 03, 07:37 AM Thread Starter
Wanted to know if you can fit a 17x8 wheel with 5 inch backspacing all the way around on a 69 camaro. I know most people go with 4 3/4. The wheels I like only come with 4 inch or 5 inch backspacing. I know 4 inch will not work but the 5 might. The car will have a full hotchkis suspension with 2 inch lowering springs in front & 1 1/2 lowering springs in the rear. It will also have baer brakes all the way around. If they will fit I was thinking of running a 235/45/17 for the front and a 255/45/17 for the rear. Thanks for any help
green 69 is offline
post #2 of 3 (permalink) Old Sep 24th, 03, 02:12 PM
Gary
MangeMD's Avatar
Talking
You can use the 'search' feature and find the answer to your problem, however those sizes will fit.
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #3 of 3 (permalink) Old Sep 25th, 03, 11:34 AM
After doing a search(s) and reading thru 50+ messages, info on 5" bs is somewhat limited. Below are some tidbits I've gleaned:
From Chevy High Perf mag(issue was Jan 2001), they say the following is max for 1st Gen
FRONT
15-inch
Backspacing: 3.75
Wheel: 7.0
Tire: 225/55
16-inch
Backspacing: 5.0
Wheel: 8.5
Tire: 245/50
17-inch
Backspacing 5.0
Wheel: 8.5
Tire: 245/40
REAR
15-inch
Backspacing 4.875
Wheel: 8.5
Tire: 28x10.5
16-inch
Backspacing: 5.5
Wheel: 8.5
Tire: 255/50
17-inch
Backspacing: 5.5
Wheel: 9.5
Tire: 275/40
Also, this site is handy for calculations:
http://www.rsracing.com/tech-wheel.html#wheeltrm
I have the exact setup you have as far as suspension is concerned and hope(pray) that 17x8 5bs will work. Ordering American Racing 200S wheels that only have the 5bs available
torose is offline
