17 x 9 with 6" BS to much? - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 1st, 03, 05:46 PM Thread Starter
MStennes's Avatar
I have been researching 17 inch wheels very hard and keep comming up empty handed in Torq Thrust 2's they only come in 17 x 8 with 4.5 bs and 17 x 9 with a 6 bs so I'm back to forged Cragars but the come in at 17 x 8 with 4.5 bs and 17 x 9 with a 6 in backspace. Will these work and how wide of a tire can I run on the Cragar backspace?
Thanks in advance,
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
MStennes is offline
post #2 of 6 (permalink) Old Oct 1st, 03, 07:06 PM
Jody
camcojb's Avatar
The rears will rub on the inside, real bad if you have drum brakes. I guess you could use a spacer but I'd avoid it myself. The TTII's come in the exact backspacing you need as a custom offset. I got the last set of four ( two 17X8" with 4.75" b.s. and two 17X9.5" with 5.5" b.s.) for just over $1100. delivered.
The fronts ideally would have 4.75"-5" b.s. but as long as the front of the car isn't really low the 4.5" b.s. should be okay. I ran 245/45's up front and 275/40's in the rear.
Jody
camcojb is offline
post #3 of 6 (permalink) Old Oct 2nd, 03, 03:18 AM Thread Starter
MStennes's Avatar
Jody,
I'm running a Hotchkis suspension all the way so I'm down 2 up front and 11/2 in the rear will this set up still work? I looked on the Torq Thrust site and they did not show the 5.5 only 7 I beleave where did you get yours?
Thanks,
MStennes is offline
post #4 of 6 (permalink) Old Oct 2nd, 03, 04:17 AM
Jody
camcojb's Avatar
Mike,
They definitely offer the correct backspacings for your car; they just call them custom offsets which cost a little more. I got mine here:
http://www.wheelsforless.com/
Jody
camcojb is offline
post #5 of 6 (permalink) Old Oct 2nd, 03, 07:07 AM
Jeff
jg95z28's Avatar
Send a message via AIM to jg95z28
$235 each huh? Then the $256 quote I got from Big-O wasn't too bad.
BTW, I think I'm going with 17x8 4-3/4" with 245/40's on all four corners.
'67 RS Coupe - Gold on Gold, 327/210, PG and mostly original
'67 Plain Jane Coupe - Penske Blue, Z/28 stripes, 350HO & Tremec TKO500
'95 Z28 Coupe - Dead stock (seriously)
jg95z28 is offline
post #6 of 6 (permalink) Old Oct 2nd, 03, 09:25 AM Thread Starter
MStennes's Avatar
Cool
I'm going to try 245 45's in front and 275 45's in the rear and hope she doesnt rub. I hope it will work with the front being lowered 2" and the rear 11/2". But that is the look I want.
MStennes is offline
