How much air pressure should air shocks have? - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 13th, 03, 11:30 AM Thread Starter
The air shocks were on the 69 when i got it and i am wondering whats the max. pressure to put in them.Not sure what brand but they are white
shockers69 is offline
post #2 of 5 (permalink) Old Nov 13th, 03, 11:36 AM
They are probably Gabriel High Jackers. A good recommended pressure to keep them at is about 45 - 50 PSI. Any more than that and the ride is too stiff. I believe that the minimum is 35 PSI and the max is around 120 PSI but I could be wrong. I have been before. I have a pair on my 69. I keep them at 50. The ride is smooth and the car stays level. Click on the link below and you will see how the car sits.
69X11SS is offline
post #3 of 5 (permalink) Old Nov 14th, 03, 08:49 AM
DjD
DjD's Avatar
My '86 El Camino has factory air shocks and the door sticker says max 65psi when filled with an empty bed, max 90psi is bed is fully loaded...
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Nov 14th, 03, 09:28 AM
How high are you trying to raise it? On mine, I just try to keep the body level so I only put in a little air. I have never checked to see what the pressure is though. Even at that it gives me a poor ride
1970 original owner, F41
bowtie-70 is offline
post #5 of 5 (permalink) Old Nov 15th, 03, 02:34 AM Thread Starter
Well since some numbskull put a 12 bolt 1970 chevelle rearend(thats 2" wider and rubs the tires when someone is in the back seat)i have to keep it jacked up pretty high.
