Acorn lug nuts - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 15th, 03, 08:08 AM Thread Starter
Ray
My 67 camaro came with the extra long wheel studs (commonly used in drag racing) from the previous owner. The 17" wheels I have use the acorn/tapered style lug nuts.
Is there such a thing as open ended acorn lug nuts? High quality chrome type, not the ones used with rallys under center caps.
Or do I have to change out all 20 wheel studs to the factory length?
Ray
Rayzor is offline
post #2 of 6 (permalink) Old Nov 15th, 03, 09:17 AM
Jegs or Summit have a whole list of styles , lenghts , and sizes. Also you could try your local wheel/tire dealer.
68 Camaro~LSx ~all motor
post #3 of 6 (permalink) Old Nov 15th, 03, 10:17 AM Thread Starter
Ray
Thanks Doug, I looked at summit and jegs but they only have open ended nuts in the mag/shank style (sst, s/s and pro mag)All the acorn/tapered style are closed ends. Ray
Rayzor is offline
post #4 of 6 (permalink) Old Nov 15th, 03, 01:13 PM
Cool
I screwed my McGard's or whoever on my new Bullitt's with longer 1/2" studbolts that are on my car AND the sucker's popped the center Acorn "cap" outta three of them with hardly a dimple!!
Supprised the heck outta me b/c I thought I was going to have to cut the tops off to work right!!
You might try and see if the "cap" won't pop out??
pdq67
post #5 of 6 (permalink) Old Nov 15th, 03, 03:37 PM
ARE-881140 Accessories, Lug Nut, Open End 19mm Bulge Acorn, 7/16" Thread, Each (due in 11-25)
GOR-90077 Acorn bulge open end style, 13/16 in. hex, 7/16 in. thread, chrome plated, lug nuts (in now)
These are just 2 off the top.
post #6 of 6 (permalink) Old Nov 15th, 03, 08:38 PM Thread Starter
Ray
Pdq67 I also have the stock short acorns. The center was either drilled out or the stud was forced through the cap(came that way from previous owner). I was just looking to see if I could get open ended ones/or extra long ones to replace mines.
Doug G Thanks for the numbers.
Ray
Rayzor is offline
