c4 or c5 Vette wheels on 69 Camaro? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 5th, 04, 04:38 PM Thread Starter
Anyone know if this is possible? Pictures if it is?
billyd is offline
post #2 of 3 (permalink) Old Mar 6th, 04, 04:47 AM
It's possible, I've got them on my 1968: 9.5-18's with 275-35's on the back and 8.5-17's with 245-45's on the front. (Sorry, I don't have any pictures.)
Depending on your brakes (disk or drum) you need a 1.75 to 2.0 inch bolt-on spacer (the spacer bolts onto your existing wheel studs and the wheel bolts on to the spacer), and perhaps longer wheel studs. I've got 2.0 inch spacers front and rear. I had to "clearance" the inner rear wheel wells a bit, and at full lock the front tires rub slightly on the subframe.
On the rears, you can get the wheels and tires in easily, but you need to account for the movement of the tire in the wheel well when one side of the rear is higher than the other, for example when going into a driveway at an angle.
I like the look a lot, and it's one of the cheaper big wheel solutions out there.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #3 of 3 (permalink) Old Mar 6th, 04, 06:33 PM
www.wheeladapter.com
89 C4 Coupe/Z51/ZF6/J55
Sold the 69
TOMS69 is offline
