67 street wheels.. - Team Camaro Tech
post #1 of 8 (permalink) Old Mar 8th, 04, 04:54 AM Thread Starter
hi guys have a 67 ss that i am looking to put some wheels and tires on.. what is a good standard size to work with to give it an agressive look but keep it under the fender wells?
i was looking at American Racing Thrust II wheels something like 17" but i did'nt know which backspacing would fit and then maybe use 235 40 17 tires in the front
and 275 40 17 in the rear.. hope someone can help....
JWLambertson is offline
post #2 of 8 (permalink) Old Mar 8th, 04, 09:07 AM
If you do a couple of searchs on this topic you'll find all kinds of info and some pics to help you make your decision. Most people will tell you that 17x9.5 with 5.5 BS will fit a 275/40 in the rear. Like I said, with a little searching, you'll have everything you need to know. Good Luck!
John68rs is offline
post #3 of 8 (permalink) Old Mar 8th, 04, 09:15 AM
17x8x4.5 or 4.75 with a 235/40/17
17x9.5x5.5 with a 275/40/17
chicane67 is offline
post #4 of 8 (permalink) Old Mar 8th, 04, 03:23 PM
Gary
MangeMD's Avatar
Angry
17x8 with 5"bs if you are running discs, 4.75" for drums, with 235/40-17's
17x9.5 rear with 5.5"bs discs, 5.25" drums, with 255/40-17 or 275/40-17 (tight fit-may rub on some turns/bumps).
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #5 of 8 (permalink) Old Mar 10th, 04, 04:46 PM
Jeff
jg95z28's Avatar
Send a message via AIM to jg95z28
On the 67 coupe I'm running 235/45 on 17x7 w/ 4.25 front and 255/45 on 17x8 w/ 4.75 rear with the stock suspension. (Tires are Dayton Daytonas, wheels by Boyd.)
'67 RS Coupe - Gold on Gold, 327/210, PG and mostly original
'67 Plain Jane Coupe - Penske Blue, Z/28 stripes, 350HO & Tremec TKO500
'95 Z28 Coupe - Dead stock (seriously)
jg95z28 is offline
post #6 of 8 (permalink) Old Mar 11th, 04, 06:15 AM Thread Starter
i see alot of sites like wheelsforless.com and others with wheels available for sale in 17 x 8 with 4 3/4 back spacing but i don't see any sites that have 17 x 9.5 with 5 1/2 bspacing... any ideas???
post #7 of 8 (permalink) Old Mar 11th, 04, 06:19 AM Thread Starter
also on my ride right now i have Mickey thompson indy profile L60 in the rear which have a heighth of about 28".. they rub when i hit a bump or three big people in the back... i am hoping 275 40 17 will have a heighth of 25 3/4" which should definitely be alot better on the ride and still close enough to look good from the side...
what do you think?
post #8 of 8 (permalink) Old Mar 11th, 04, 11:30 AM
You'll have to check with manufacturers to get the specific BS you need. I emailed a lot of the web retailers before I bought and they would give me a quote and be able to get the product even though it wasn't listed on their site. Tirerack.com has a calculator to help with exact measurement issues. Good luck!!
John68rs is offline
