Will 16x8, 5.0 b.s. work all around on a 68? - Team Camaro Tech
post #1 of 10 (permalink) Old Mar 12th, 04, 04:26 AM Thread Starter
I wanted to order some 16x8 Centerlines, but can only get the ones I want in a 5" BS. I currently have stock suspension, but plan on moving to the Hotchkis setup on front and rear. I'm not picky on tire sizes, but I want to make sure I won't have clearance issues on either the front or rear before I order. I know 4.5 is the standard, but will 5.0 work okay too?
BTW, I've searched and searched, but there are only so many posts I can read! [img]graemlins/clonk.gif[/img] Thanks for the help!!
"Never raise your hands to your kids. It leaves your groin unprotected." - Red Buttons
Paul H. is offline
post #2 of 10 (permalink) Old Mar 24th, 04, 09:44 AM
Hey Guys,
Can anyone help with this answer? I don't think the rear is a problem but what about the front?
I will be running 16x8 5" BS with 255/55/16 on the front.
Thanks!
Mike68RS is offline
post #3 of 10 (permalink) Old Mar 24th, 04, 11:51 AM
Paul
PDQUICK's Avatar
I'm running 16" x 8" wheels with 4.625" back spacing and 245-45's on my '68 which is lowered 2". I'm not 'positive', but pretty sure that with 255's and .4" more backspacing I would be on the rear quarters and probably rubbing the front fender lips! Might not hit in a straight line, but I don't know about turns in full bump!! I'll make some measurements tonight.
Paul D.
PDQUICK is offline
post #4 of 10 (permalink) Old Mar 24th, 04, 07:14 PM
Carl
I have 16" x 8" x 4.5"bs Vintage Wheel Works rims. If I had a choice I would opt for a 5" backspace.
With a 245/50 tire on the front they would rub on the frame at full lock. It might be necessary to limit the turn radius a bit. With a 225 or narrower tire it may not be a problem.
The nice thing about the 5" bs is that more castor can be added. With mine 4* is the max before the outside of the tire starts to rub on the lower-bottom-outside of the wheelwell. A 5" bs would allow a bit more castor.
On the rear it will rub when the suspension is highly articulated, such as going up a driveway sideways, with a 255/50 tire. A 245 will allow a bit more freedom.
CarlC is offline
post #5 of 10 (permalink) Old Mar 25th, 04, 04:03 AM
I have 225/50's(4 1/2 b.s) on the front and they dont hit at all, I do know the 235/50's did rub just a spec on the frame when turned all the way so I would have to let up and not turn so hard..
1967Camaro327 is offline
post #6 of 10 (permalink) Old Oct 25th, 05, 09:26 AM
Re: Will 16x8, 5.0 b.s. work all around on a 68?
I know this is an old post but I was hopping to get some feed back. I would like to run 16x8 on all fours and 255/50r16 in the front. I have no wheel wells and the front is dropped 1” with GW upper and lower tube a-arms. I was panning on getting 4.5” BS but after readying this post I need to ask, will a 5: BS help or should I stay with 4.5”BS? Right now I am running 15x8 and 235/60R15 and not even close to the frame!
1968 Camaro.....
fish763 is offline
post #7 of 10 (permalink) Old Oct 25th, 05, 11:58 AM
what is the backspacing on your rims you have now?
you should just be able to look down thru where you inner fenders should be and see how much more clearance you have to fit more BS
400bird is offline
post #8 of 10 (permalink) Old Oct 26th, 05, 10:43 AM
I also have a set of 16x8 Vintage Wheel Works front and rear. 245/50-16 all around and the front tires rub like crazy because I dropped the car 2" up front. Wish I would have went 225/50 up front now looking back. 500 miles and my front tires are trash already.
Chris-in-Cali is offline
post #9 of 10 (permalink) Old Mar 17th, 06, 10:09 AM
Sorry, I have been off line for a wile due to work. I will pull the wheel and check it to night. I think it has a 5” bs but I need to verify. I have also been reading posts about 17x8 and looking at tires becasue the 16 are getting a little low in choices. I would like to stay with the 16x8 but it would be nice to know it the tire size I go with now will still be around when I need to replace the rubber in the furture.
1968 Camaro.....
fish763 is offline
post #10 of 10 (permalink) Old Mar 27th, 06, 04:53 PM
Mike Petrovich
fish763: Were you running 15x8 235/60R15 all around? I have all drum brakes and am not sure what bs I should use for same size you mentioned or 15x7 235/60R15 (on all 4 wheels). Thanks.
1968 327 sport coupe. Son of original owner.
mike p is offline
