adapters - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 15th, 04, 08:16 AM Thread Starter
I picked up some 10 inch mag wheels and eventhough the bolt pattern fits the center hole on the rim is about half an inch in diameter larger than the hub. Is there an adapter for this? I don't want to bring the wheel any further out and all the adapters I have seen will do this.
Mister G is offline
post #2 of 6 (permalink) Old Mar 16th, 04, 11:33 AM Thread Starter
http://www.fattonyracing.com/Guyscamaro/DSC00378.JPG
This is what I am talking about, if my message was not clear.
Mister G is offline
post #3 of 6 (permalink) Old Mar 16th, 04, 11:48 AM
Smile
You can have a machine shop make you some short cylinderical spacers that are like block cylinder sleeves that have a flange on them so when the wheel is put on they can't fall out the front.
This has been mentioned with respect to rotor holes being over sized so isn't all that big a deal, imho..
Shouldn't be much of a job at all unless it flat costs too much machining and set-up time.
pdq67
post #4 of 6 (permalink) Old Mar 16th, 04, 02:41 PM
Jody
camcojb's Avatar
I'm still trying to figure out what the problem is!!!! LOL!!!!!!! Many wheels are lug-centric, meaning they center off the lugs/studs just like the one in the picture. They work fine that way.
Jody
camcojb is offline
post #5 of 6 (permalink) Old Mar 17th, 04, 04:36 AM Thread Starter
You maybe correct! My concern is the forces applied are only distributed by the lug nuts. I would have believed that if it fit properly that the axle hub or whatever it's called would also aid in the distribution of load.
Mister G is offline
post #6 of 6 (permalink) Old Mar 17th, 04, 04:53 AM
Jody
camcojb's Avatar
Hub-centric has to be stronger still, but most all aftermarket wheels aren't built that way anymore, at least from the ones I see. I've had lug-centric wheels on virtually every car I've owned and never had a problem.
Jody
camcojb is offline
