Tire size? - Team Camaro Tech
post #1 of 17 (permalink) Old Mar 24th, 04, 03:46 AM Thread Starter
Hi, I am new here and this is my first post. I would appreciate any help you guys can offer.
I have a set of 15 x 7 ralley wheels I am going to put on my 67. What size tire do some of you guys run on this size wheel? Please post pictures if possible.
thanks
Darran<br /><br />'67 Camaro <br />'69 Chevelle SS396/TH400
Sandite67 is offline
post #2 of 17 (permalink) Old Mar 24th, 04, 05:58 AM
Tim
I have 15x7's on the BACK of mine and I run 255/60/15. The wheels are a stock Monte Carlo offset. Also it is lowered 2". HTH,
Tim
67 Camaro RS
64 Nova SS
"Pay attention, there's gonna be a test later."
Chevy Kid is offline
post #3 of 17 (permalink) Old Mar 24th, 04, 09:00 AM
Call me Funk
Send a message via AIM to CFunK
Sandite67,
First off Welcome Aboard!
This subject has been beaten to death. Try running some searches, I have a feeling you will find the answer you seek.
FYI: I run 235/60/15's on the front.
-Funk
CFunK is offline
post #4 of 17 (permalink) Old Mar 25th, 04, 08:59 AM
For what ever it's worth here is a shot of what 295/50x15 look like......
Mister G is offline
post #5 of 17 (permalink) Old Mar 25th, 04, 11:08 AM
jake bohannon
Welcome to Mecca!!
You won't be new here for long, Since my inception, I am here every day. I run 235/60/15 rear and 215/60/15 front. Moog 6306 front and Hotchkis 1.5 drop rear.
:href="http://home.mchsi.com/~jakeman23" target="_blank">http://home.mchsi.com/~jakeman23</a>
1stGenJake69 is offline
post #6 of 17 (permalink) Old Mar 25th, 04, 11:10 AM
jake bohannon
1stgenjake 69 camaro See first photo white white letter, others are before new tires, also suspension not installed in these pics
post #7 of 17 (permalink) Old Mar 25th, 04, 02:24 PM
D
Sand,
Be careful. I also run 235/60/15s on the front (and rear) however my 68 is 99% original. Which means my springs and shocks are original, and in need of replacement. Just make sure you have a descent set of springs. With 15x7s, you should be more than fine! Welcome!
1969 Camaro X11
L14 307ci/200HP base V8
PowerGlide
Factory AC
62,000 Original Miles
Prior 1968 Camaro
210HP Turbo-Fire 327-2V
PowerGlide
Domano 68 is offline
post #8 of 17 (permalink) Old Mar 25th, 04, 09:09 PM
Call me Funk
Darran,
What is the backspacing on the rims you bought?
-Funk
CFunK is offline
post #9 of 17 (permalink) Old Mar 26th, 04, 06:16 AM Thread Starter
I believe the backspacing is 4-1/2. I will double check that(I have had the wheels for quite a while and I need to refresh my memory). thanks for all the responses and help.
post #10 of 17 (permalink) Old Mar 26th, 04, 06:33 AM
Call me Funk
If they have a 4.5" BS you should have no trouble using a 235/60/15 tire all the way around.
-Funk
CFunK is offline
post #11 of 17 (permalink) Old Mar 26th, 04, 09:19 AM
Might be close. My 8" ralleys have 3.75" backspacing with 245/60x15's and there is about 1" clearance to the inside wall.
Mister G is offline
post #12 of 17 (permalink) Old Mar 27th, 04, 04:23 AM
245/60/15's 8"w wheels 4.5" bs. rear. Front 15x5 w/ 3.5"bs and 205/60/15s. pics in link.
[ 03-27-2004, 08:19 AM: Message edited by: DOUG G ]
68 Camaro~LSx ~all motor
post #13 of 17 (permalink) Old Mar 27th, 04, 04:36 AM
Hey Mister G, I have those same slotted mag wheels as you and i just ordered some T/A 295-50-15s, my wheels are 15x10 with about 3.75-4'' BS , i hope it sits similair to yours, looks really sharp!
Adam
Drag67Camaro is offline
post #14 of 17 (permalink) Old Mar 27th, 04, 02:35 PM
MisterG,
What are the "metric" converted tape measurements of the dia. and section width of your mounted 295's??
I am just curious to know if they really measure a true 295.
I know my old L-60/14's measured a 298/53-14 on my old 14" x 9" Fenton slots like yours. So they were by no stretch a 60 tire, imho!!
pdq67
post #15 of 17 (permalink) Old Mar 27th, 04, 04:58 PM
Fronts= 215/65/R15
Rears = 255/60/R15 on Rallys.
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve W is offline
