broken stud... - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 12th, 04, 01:34 PM Thread Starter
I as wondering the best way to take a broken lug stud out of my back drum..Do I have to press it out or what. If so then do I have to take the drum/shaft off.. Thanks in advance for any and all help...
69 camaro ss 383/brodex heads/msd gold box 600hp 11.19 @126mph
skibum is offline
post #2 of 7 (permalink) Old Apr 12th, 04, 01:58 PM
Kevin
The wheel stud pressed into the axle from behind and just goes through the brake drum. You may be able to carefully drive the old stud out with a large drift and hammer. Good Luck Neighbor Kevin
KRhat is offline
post #3 of 7 (permalink) Old Apr 12th, 04, 03:37 PM Thread Starter
Thanks kevin, I'm wondering if anyone out there has fabed up some sort of press to do it(remove broken stud) right on the car. If not what else I can do..Must fix too much hp. to run on 4 studs.
skibum is offline
post #4 of 7 (permalink) Old Apr 12th, 04, 04:04 PM
Tony
Send a message via AIM to tony -Di
tony -Di is offline
post #5 of 7 (permalink) Old Apr 12th, 04, 04:11 PM
Tony
Originally posted by tony -Di:
</font><blockquote>quote:</font><hr />Originally posted by KRhat:
</font>[/QUOTE]i recently had to replace the studs on the rear of my 67 i i removed the drum positioned the stud to a area that i could back up the axle next to the stud with a steel bar and used a punch and hammer to drive each stud out to put the studs back in i used large washers to draw them in with the wheel nuts
tony -Di is offline
post #6 of 7 (permalink) Old Apr 12th, 04, 04:15 PM Thread Starter
thanks tony
skibum is offline
post #7 of 7 (permalink) Old Apr 15th, 04, 05:10 AM
I just changed my studs when I rebuilt the rear end. When I was done I discovered that one stud on the rear had bad threads. Like the last post I used a bar and hammer with punch. I put the bad stud toward the front and applied pressure between the hub and brake shoe. Then I gave the stud a healthy whack with the hammer to get it going and finished with the punch. After I replaced the wheel I torqued them all to 90 ft.lbs. and took it for a 20 mile drive. I retorqued them and everything is fine.
deerhunter is offline
