14 x 7 SS Rim Code Help - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 18th, 04, 09:59 AM Thread Starter
USN1969SS's Avatar
I have searched fruitlessly for this to no avail. Can anyone decipher these alpha/numeric codes on my rims? The rims are the 5 spoke SS type.
Outside by valve stem is "4 (valve stem) 23 AO"
Stamped between rim "14 x 7 JJ" Below this is "8 87"
No other markings except "made in MI". I know the MI is Michigan and the 14 x 7 is rim size but do not know what the rest means.
Thanks for any and all replies.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
USN1969SS is offline
post #2 of 2 (permalink) Old Apr 18th, 04, 11:33 AM
Jeff
jg95z28's Avatar
Send a message via AIM to jg95z28
Outside
4 = April
23 = 23rd day
AO = Correct for late 69 SS Camaro or SS Chevy II on 14x7 JJ (Could also be early 1970, however I don't have the numbers past 1969.)
Inside
14x7 = size of course
JJ = the rim contour type
8 87 = should be the date that part of rim was run. 8 being the day of the month. Not sure on the 87, usually there is a letter here. The inside number is only the date that piece was made, while the outside number is the dated the rim was completed.
'67 RS Coupe - Gold on Gold, 327/210, PG and mostly original
'67 Plain Jane Coupe - Penske Blue, Z/28 stripes, 350HO & Tremec TKO500
'95 Z28 Coupe - Dead stock (seriously)
jg95z28 is offline
