The Right Fit - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 20th, 04, 03:45 PM Thread Starter
I have 67 Camaro, I have a 2inch front drop coils from detriot speed and 2inch rear drop.
I am having problems with front rims and tires fitting. I called detriot speed about tire sizes but ther suggestion does not work.
centerline wheels
17 inch
front 8 inch rim
4.25 backspacing
245/45/17 To big they rub on outside fender lip
225/45/17 To big they rub on outside
205/35/17 to small not enough side wall
I have spent alot of $$$$ on tires need to know what will work?
Thank,
sosexpress is offline
post #2 of 3 (permalink) Old Apr 20th, 04, 04:47 PM
Jody
camcojb's Avatar
The backspacing on the wheel is wrong. You need 4.75" to 5" b.s. on a 17X8" front wheel. Then the 245/45 will fit without issue.
Jody
camcojb is offline
post #3 of 3 (permalink) Old Apr 21st, 04, 06:52 PM
Yep, 5.00 for drum 4.75 for disc. No offence but this has been gone over about a billion times on this board alone
-HOT OHC
HOT OHC is offline
