Space Saver Space Tire - Team Camaro Tech
post #1 of 7 (permalink) Old May 7th, 04, 07:58 AM Thread Starter
Can I get a space saver spare tire from another GM car for my 68 Camaro? I have no spare and I'm taking it to Maine in 2 weeks. Will a space saver doughnut wheel work from a Cavalier or Malibu or something?
Green Hornet is offline
post #2 of 7 (permalink) Old May 7th, 04, 08:38 AM
Tim
I believe the Cavalier or Malibu would have the wrong bolt pattern. However there are lots of GM cars in the boneyard with a 5 on 4-3/4 bolt pattern. That's what I have in my 67. Never had to use it so far, but it really helps with the trunk space.
Tim
67 Camaro RS
64 Nova SS
"Pay attention, there's gonna be a test later."
Chevy Kid is offline
post #3 of 7 (permalink) Old May 7th, 04, 01:05 PM
If you have disc brakes, you can not fit a regular first gen space saver spare. Just a thought.
-Mark.
stingr69 is offline
post #4 of 7 (permalink) Old May 11th, 04, 07:26 AM Thread Starter
Well the plan was to retro fit a space saver from a newer car. And yeah I have the front disc brakes.
post #5 of 7 (permalink) Old May 11th, 04, 09:35 AM
DjD
DjD's Avatar
Are your disc's stock or larger conversion brakes. I think you'll find a a spare from a modern Vette, Camaro or maybe even a 2000 or newer Impala might work for you. The key besides fitting on is getting as close to the same height as the other tires as you can. If you end up with a shorter spare and have to use it, keep your speeds down and get the tire fixed asap to reduce bearing stress...
...Dennis
DjD is offline
post #6 of 7 (permalink) Old May 11th, 04, 12:27 PM
click's Avatar
My boneyard found that the early 80's mini blazer had a space saver that was the right bolt pattern and fit their disc setup, so I bought one to save space in the trunk for our trips. I have not had to use it yet, maybe I should double check its fit? The height of the spare will be important if you have a posi. and get a flat in back.
[img]graemlins/clonk.gif[/img]
click is offline
post #7 of 7 (permalink) Old May 12th, 04, 07:39 AM Thread Starter
So I've done alot of calling and Montreal boneyards are just filled with disposable japanese cars.
