Help on Rim size PLEASE! - Team Camaro Tech
post #1 of 4 (permalink) Old May 23rd, 04, 04:19 AM Thread Starter
I have a 69 Camaro with Drum brakes all around. I found some Draglite rims i want to put on it. 15+8 in the rear and 15+6 in front. The back spacing for both is 3.5 and the bolt pattern is 5+4.75/5. Would this work? Thanks in advance
George
geosel2 is offline
post #2 of 4 (permalink) Old May 23rd, 04, 04:39 AM
Jody
camcojb's Avatar
Not on the rear. Not enough backspacing to get any decent sized tire inside the fenderwell. If you wanted to run air shocks and have the rear of the car way up in the air it might work.
A 15X8" wheel on the rear needs about 4.75" to be centered for a larger tire, but 4.5" to 5" will work in many cases. 3.5" of b.s. is simply not enough.
Jody
camcojb is offline
post #3 of 4 (permalink) Old May 24th, 04, 02:52 PM
Jody,
What company would you recommend to get the 18 by 9's and 18 by 8's with the backspacing you recommended in another post? [img]graemlins/hurray.gif[/img] 67 RS/SS Convertible Project
DaMan2 is offline
post #4 of 4 (permalink) Old May 24th, 04, 04:11 PM
Jody
camcojb's Avatar
Originally posted by DaMan2:
Jody,
Many offer them, but it depends on what you like and what your budget is.
Jody
camcojb is offline
