Used Rally Wheels? - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 9th, 04, 03:17 PM Thread Starter
What should I look for when purchasing used rally wheels.
Date codes don't matter too much to me, I want 15x8 or 15x7's
I am hoping to find some at Carlisle.
I have bought new brakes
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
And downloaded the template from www.baer.com
Do you think they will fit? The template say they need 7.02 from the center to clear.
TIA
drewbird911
drewbird911 is offline
post #2 of 7 (permalink) Old Jun 9th, 04, 04:44 PM
Charles
i would do a search in the wheel and tires section. this subject has been beat to death with all the different choices of wheels, tires, brakes and suspension set ups out there. search for things like backspacing, tire size, stance, wheel size, baer disc brakes. tons of info just gotta sit down and look thru it and decide what you need, want, and can afford.
i'm sure some guys with baer brakes will chime in with their set ups.
good luck!!
BELIEVE IN YOUR DREAMS
1969 SS X55 NOR added RS all NOS sheetmetal, ground up resto. 24 year project and dream. optioned out the wazoo. in one thousand pieces, and coming together finally.
Run269 is offline
post #3 of 7 (permalink) Old Jun 10th, 04, 12:06 PM
Dan
15 x 7 4.25 backspace from a 70's monte carlo will fit. I needed a 7/32" wheel spacer to make them clear using 12" pbr caliper/rotors. (and a 1/8" off the corner of the caliper.) -Dan
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
post #4 of 7 (permalink) Old Jun 10th, 04, 04:21 PM Thread Starter
Angry
[img]graemlins/waving.gif[/img] Thanks!
I knew you guys would come through
15x7 or 8 I assume will work, but I may need a spacers. I hope I can find a nice set at Carlisle
Thanks Again
post #5 of 7 (permalink) Old Jun 18th, 04, 01:36 PM Thread Starter
Angry
[img]graemlins/hurray.gif[/img] I found a nice set of 15x8 [img]graemlins/angry.gif[/img]
What size tires now?
post #6 of 7 (permalink) Old Jun 18th, 04, 01:49 PM
D-
Do a search on here for "tire". You'll find a ton of stuff. Most say 255 60 15 is biggest without rubbing. I looked at a Cortez Silver 69 Z at Carlisle today with this size trie, and it looked "right". Not as good as "The Mule", but...
Eric
Eric Kammerer is offline
post #7 of 7 (permalink) Old Jun 22nd, 04, 07:17 PM
I've got 265\50R15 BFGs on 15x8 vette ralleys (front), and 295/50R15 BFGs on a 15x10 Wheelvintique (rear with 6" offest). Fronts are tight and will rub if your camaro sits too low - my 69 sits up a bit (2-3") between top of the tire and bottom of fender. Thr rears will not work unless you move the rear shocks inboard - Comp Enginnering makes a kit. I built mine. good luck!!
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
