weld draglites 15x10 - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 11th, 04, 12:24 PM Thread Starter
Will theese fit my 69 Camaro with stock wheel tubs? Am I going to need adapters for the bolt pattern?
Thanks, Tim
rear 15x10 8" bs
front 15x4 2" bs
bolt pattern 5 x 4.5 and 5 x 4.75
Timbo_1969 is offline
post #2 of 6 (permalink) Old Jun 12th, 04, 12:09 PM
Bryan
The bolt pattern is fine, plus I think the fronts are fine, but that 8 inch backspacing is pretty huge. Typical backspacing for our Camaros is around 4.5 inches.
1968 Camaro, 383 with Dart Pro 1 aluminum heads and roller cam, Holley Sniper EFI with Dual Sync distributor, Muncie M21 4-speed transmission, 3.73 12-bolt Eaton posi differential.
Bry68 is offline
post #3 of 6 (permalink) Old Jun 15th, 04, 01:18 PM
6D9
Ron
Yeah...no way those suckers will fit. I am running 15x8's with 4.5 bs on 275/50/15's. They just barley clear. The fronts will work great though.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #4 of 6 (permalink) Old Jun 23rd, 04, 02:47 PM
You can fit a 15X10 under a '69, but it requires a 5" B/S and rolled fender lip and some hammer surgery on the inner wheel well. After all that a 295 tire will fit....barely
Viva La France...She's always there when she needs you
HeadHunter is offline
post #5 of 6 (permalink) Old Jun 23rd, 04, 03:31 PM
Jody
camcojb's Avatar
I'm not sure how a 15X10 would clear that way. We did a 15X8" with 5" b.s. and BARELY cleared even with a rolled fender lip and a 275/60 tire. Not sure how you can bring the wheel 2" further out and get it under the fender. Air shocks maybe.
Jody
camcojb is offline
post #6 of 6 (permalink) Old Jun 25th, 04, 03:15 PM
I saw the car at Cruisin the Coast this past year and that is what he told me he did....just passing it along. I don't remember if he had Air Shocks...maybe.
