Widest Tire for '67 14x6 Rally's? - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 22nd, 04, 05:59 PM Thread Starter
What's the widest tire you can go with on a stock 14x6 rally rim for a '67? I've got 245's on my '67 and they rub, when I'm at full steering lock during a u-turn. Ugh! Maybe I should go to 225's in the front?
SFCamaro is offline
post #2 of 6 (permalink) Old Jun 22nd, 04, 07:23 PM
ride height will affect your tire clearance some - so will the rim offset - I've got 265\50R15 BFGs on 15x8 vette ralleys (front), and 295/50R15 BFGs on a 15x10 Wheelvintique (rear with 6" offest). Fronts are tight and will rub if your camaro sits too low - my 69 sits up a bit (2-3") between top of the tire and bottom of fender. Thr rears will not work unless you move the rear shocks inboard. More rubber than most use with out going to a 17" rim....sorry this doesn't answer your question - hope to give an idea of what you could fit in there! Good luck!!! [img]graemlins/beers.gif[/img]
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #3 of 6 (permalink) Old Jun 22nd, 04, 08:49 PM Thread Starter
Yeah, doesn't really answer my question. But how do I adjust ride height in the front. Just curious.
SFCamaro is offline
post #4 of 6 (permalink) Old Jun 23rd, 04, 07:28 AM
With 205 70 14 on my stock 6-inch rally rims and drum brakes, the tires rubbed on the frame toward the back of the car (behind the front wheel in other words). When I went to disks, the rubbing went away.
205 is obviously a whole lot less tire (about 2.5 inches), but a 6-inch rim just won't take much tire without too much sidewall bulge.
Eric
Eric Kammerer is offline
post #5 of 6 (permalink) Old Jul 7th, 04, 04:38 PM
Jeff
jg95z28's Avatar
Send a message via AIM to jg95z28
I used to run 235/60R-14 BFG Radial T/A's on 14x6 ralleys on my old 68 RS. It came with 225's front and 245's rear, but the 245's rubbed and I wanted to be able to rotate the tires.
That set-up will also work on a 67.
'67 RS Coupe - Gold on Gold, 327/210, PG and mostly original
'67 Plain Jane Coupe - Penske Blue, Z/28 stripes, 350HO & Tremec TKO500
'95 Z28 Coupe - Dead stock (seriously)
jg95z28 is offline
post #6 of 6 (permalink) Old Jul 9th, 04, 11:12 AM
Angry
With front discs I was running 215/60s on the front and 245/60s on the rear. No rubbing at all. Good luck!
John68rs is offline
