Rims 15x7 or 15x8 / corvette rallys? - Team Camaro Tech
post #1 of 18 (permalink) Old Jun 27th, 04, 02:38 PM Thread Starter
Hi,
I'm looking to get some rally wheels 15x7 or 15x8 for my stock 69 camaro but I'm not sure about tire fit/rub etc.
1) If I use 225/60/15 or 235/60/15 tires do these fit a 15x8 OK? I hear this size fits without rubbing.
2) Do 82 15x8 corvette rallys fit my camaro?
3) Is there an advantage to going to 15x8's in this tire size?
Thanks!
Judobear is offline
post #2 of 18 (permalink) Old Jun 27th, 04, 02:47 PM
Johnny
15" x 7" will work great on the front with the 235/60/15 tires with no rub. 15" x 8" will work on the back with 245/60/15 tires. I know this for sure as this the combo my Brother is running on his 69. you can look at it on my web site listed in my signature.
johnnyr is offline
post #3 of 18 (permalink) Old Jun 27th, 04, 06:44 PM Thread Starter
Thanks for the info and the link to the pics. What a huge job. Looks great.
Do you know what the back side offset of the wheels are? 4 or 4.5?
Judobear is offline
post #4 of 18 (permalink) Old Jun 28th, 04, 03:24 AM
Robert
I think most of the Vette 15x8's are 4"bs. I'm running 245/60/15 on 15x8 4.5"bs on the back of the '69 and they fit great. You can get more tire with less backspace in the rear of a '67 than a '69.
Robert
TC member #18
rojo is offline
post #5 of 18 (permalink) Old Jun 28th, 04, 02:40 PM
Dana
235/60-15 can rub on the front of a stock '69. I have had them on about 6 or 7 '69's and over 50% of the cars they would rub at full lock. Go with 225/60's to be safe. You can go 255/60's and even larger sometimes in the rear.
DWCamaro69 is offline
post #6 of 18 (permalink) Old Jun 30th, 04, 12:49 PM
JohnZ's Avatar
All Corvette rallys are the same from '69-'82: 15x8, -.50 offset, 5 x 4-3/4" bolt circle.
I have 235/60-15 BFG T/A's on my stock '69 Z/28 with stock "YH" rallys, and they rub on the front at full lock.
JohnZ
CRG
JohnZ is offline
post #7 of 18 (permalink) Old Jul 1st, 04, 04:56 PM
215/65R/15 will work on the front. About the same diameter as 235, but just a little narrower.
jamie
69lemans is offline
post #8 of 18 (permalink) Old Jul 4th, 04, 10:29 AM
"Tri-Tip"
Gary L's Avatar
Hey JohnZ:
Do you have a good side shot of your car that can be posted? I am at the tire/wheel decision point now and I would like to see your combo. Thanks,
Gary
Gary L is offline
post #9 of 18 (permalink) Old Jul 5th, 04, 09:12 AM
JohnZ's Avatar
This isn't a real crisp shot, but it shows how it sits - the springs are the 35-year-old originals, and it's down about an inch from factory specs. Will be putting new springs on it next winter, and I'm thinking about ditching the 235/60's and replacing them with 215's; I'm just looking for original stock ride height, but I only want to change the springs ONCE.
[img]graemlins/beers.gif[/img]
JohnZ
CRG
JohnZ is offline
post #10 of 18 (permalink) Old Jul 5th, 04, 10:58 AM
"Tri-Tip"
Gary L's Avatar
John,
The height actually looks good! What do you think about 215/65's? The 215/60's are a little short in height. Are the front springs original or Moog 6308's (or did you say ALL springs are original)?
Gary
[ 07-05-2004, 04:31 PM: Message edited by: Gary L ]
Gary L is offline
post #11 of 18 (permalink) Old Jul 5th, 04, 11:38 AM
I have corvette rallyes all around with only 4 in BS. I have 235/60 in the back and 215/60 in the front. I think it looks good and there isnt any rubbing. You could go bigger if you wanted all around
Tim
tl757 is offline
post #12 of 18 (permalink) Old Jul 5th, 04, 03:45 PM
JohnZ's Avatar
Originally posted by Gary L:
John,
Gary
Yup, all springs are original. 215/65's might be a better choice - I'll consider that. Saw a near-dupe of my car at Superfest yesterday (except it was restored) that had 215/70-15 TA's on it, and it looked pretty good too. Just want the stock look, stock ride height, and no rubbing. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #13 of 18 (permalink) Old Jul 6th, 04, 06:49 PM
"Tri-Tip"
Gary L's Avatar
John,
I second the stock ride, height and look! [img]graemlins/thumbsup.gif[/img]
Gary
Gary L is offline
post #14 of 18 (permalink) Old Jul 6th, 04, 07:16 PM
I ran a 255/60 on a 15x8 on the rear of my 67 without any problems. In fact, I had plenty of room even in the lowered position of the rear suspension.
I did however run a 15x7 on the front with a 235 with the same results.
chicane67 is offline
post #15 of 18 (permalink) Old Aug 14th, 06, 06:23 PM
Re: Rims 15x7 or 15x8 / corvette rallys?
Im running 15x7 on the front with 60 215 and 15x8 on the back with 60 255no rubbing and stock height, and no sticking out
soman is offline
