Torque thrust two on 69 convert - Team Camaro Tech
post #1 of 11 (permalink) Old Jul 2nd, 04, 08:58 AM Thread Starter
Ok I know this has bee asked before . I'm building a 69 convertable it has the stock 12 bolt rear end with cadillac rear discs , the front is stock single piston disc . Now I want to lower the car around two inches front and rear for a look like Bob Spears convert . I want to put as much rubber under the rear as I can in a 17 inch wheel , I think 7 inch will work on the front but what size for the rear and what size tires for this thing front and rear .
Please help . ps and what brand of tires should I run . street driven 600 horse motor .
pictures can be viewed at
Mark .L.W. is offline
post #2 of 11 (permalink) Old Jul 2nd, 04, 12:55 PM
Dana
Fronts: Max 8" wide, 5" backspace, 245/45-17. Rears: Max 9.5" wide, 5.5 backspace, 275/40-17. Most people say run 235/45's in front and 255/45's in rear if you don't want to take any chances on rubbing. Good Luck!
DWCamaro69 is offline
post #3 of 11 (permalink) Old Jul 2nd, 04, 03:10 PM Thread Starter
Sounds good . Now with that 5.5 rear spacing the tires will fit up inside the rear wheel wells and also clear the shocks in the stock location .
post #4 of 11 (permalink) Old Jul 2nd, 04, 06:19 PM
J
I'm running that same size on the rear. I found that on the passenger side the inside of the tire rubbed against the frame - especially on turns. No problems with the shock. I added a 5/16 spacer and havent had a problem.
I'm running the BF Goodrich g-force KDWS tires.
magisnyc is offline
post #5 of 11 (permalink) Old Jul 2nd, 04, 08:01 PM
I have a buddy that has a 650hp supercharged rustang and he has the Nitto 550's and they grip hard !! I was very surprised at how well they handle. He is useing the regular street tires not the drag radials. I think he is running a 275/45/17. Those are the tires that I plan on buying next!
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #6 of 11 (permalink) Old Jul 2nd, 04, 08:37 PM Thread Starter
Very nice looking car , I have to get off my butt and get on with mine .Those 275 sound like the way I will go also , I want to get some kind of traction when I get this going . I,m just in the process of getting my tremec 600 hundred all stuffed in there and then it's time for the exhaust . Thanks again for all your help .
Mark .
post #7 of 11 (permalink) Old Jul 5th, 04, 06:43 PM
Dana
The only problem with the 17X9.5 is they are custom order which means a little more money and a wait. Here is a pic of my RSZ with 17X7 (4" BS) and 17X8 (4.75" BS) with 235/45 and 255/45.
post #8 of 11 (permalink) Old Jul 6th, 04, 02:27 PM
This is the perfect posting. I too have a 69 camaro convertible that is due some new looks.
I think this is the combo I want to go with please let me know if anyone sees a problem.
Front is a stock suspension with the exception of hotckins 2 inch lowered springs. Stock disc brakes.
I want to go from the 215/60-15's to the 245/40-17's on a 17x8 Eagle alloy 212 wheel using 5" backspace.
Rear is stock 5 leaf set up drum brakes. I think it's old and worn out because it sits as if it's 2"s lowered. OK I have 235/60-15's would like to go with 275/40-17's using a 17x9.5 rim Backspacing 5.5.
I like the price of the Kumho ECSTA Supra 712 @$135 or the Falken FK451 @$147 Any preferences guys.
By the way new to this forum and love it.
69 Camaro SS convertible
383 Stroker Dyno @flywheel 447HP @Rear wheel 355.
4spd
White with orange stripes
Black top and Black houndstooth interior.
Sam
sgmccool is offline
post #9 of 11 (permalink) Old Jul 7th, 04, 07:12 PM Thread Starter
Is anybody running the Eagle F1 run flats , I wonder if they would have a stiffer sidewall , I like the look of the tread pattern .I want to run as much tire as I can get under the back if I could , the 275/4017 should be the max without cutting .
post #10 of 11 (permalink) Old Jul 7th, 04, 07:37 PM
A noisy, lacking life tire.
A 275 on a 9.5" rim with 4.5 to 4.75 on a 69 platform will fit just fine.
chicane67 is offline
post #11 of 11 (permalink) Old Jul 8th, 04, 02:50 AM Thread Starter
So for traction and a good ride what would be the Tire's to run .The car will only be driven on nice days .
