suspension vs. wheels - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 21st, 04, 10:27 AM Thread Starter
I am debating whether i should sacrifice the high performance suspension for the wheel combo for my 69 rs. I am planning to put the whole Hotchkis suspension package. The front will drop about 2", the bach 1 1/2". The wheels i want to go with is the american racing torque thrust II's. I want 17X8 in the front and 17X9.5 in the rear. My question is can i do both or will i ahave to pick?????? PLease help
rmfranco is offline
post #2 of 3 (permalink) Old Jul 21st, 04, 05:50 PM
Hiya - you can do both, and I'd recommend both - key is total tire height and wheel offset. I figured out what tire and wheel combo I wanted then set my suspension up to where it would clear - my camaro sits up a bit - (Front 265\50R15 BFG ob 15x8 ralley 4" offset, Rear 295\50R15BFG on 15X10 ralleys - 6" offset). You may have to sacrifice ride height a bit to get your tires to clear. Assuming you'll a 255\45ZR17 front and 285\40ZR17 tire combo? I'd find a camaro or someone who has the stance and wheel setup your after and pick thier brain - hope this helps just a bit....
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #3 of 3 (permalink) Old Jul 21st, 04, 11:22 PM
Chris
130fe's Avatar
Angry
Rmfranco, this setup is popular among pro-tourers. The 69's have more clearance then the 67/68's do. Depending on your brake setup up front (disk or drum for backspacing), fronts- 17x8 (either 235 or 245/45) and the rears 17x9.5 with 5.5 in back spacing (275/40 tires). I am in the process of installing this type of setup in my 68 and have not had any problems. Search this board and over at www.pro-touring.com and you will find a wealth of knowledge on this subject. Hope this helps.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is online now
