After-market trim rings are junk - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 29th, 04, 06:02 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Has anyone put on the aftermarket 15x7 trim rings (made in China). I bought some because I have FW wheels not YH wheels. The front rings are "walking" on the clips and cutting the valve stem. It is a good scam to sell the whole set for $79 then get mad at them to pay $350 for GM set! AAAAARRRRH!
They are from a major parts supplier whose ad reads "Quality made in the USA" when the rings are clearly stamped made in China on the back!
[ 07-29-2004, 09:46 PM: Message edited by: Gary L ]
Gary L is offline
post #2 of 6 (permalink) Old Jul 29th, 04, 07:19 PM
Vintage 68's Avatar
Talking
"ad reads "Quality made in the USA" when the rings are clearly stamped made in China on the back!"
Maybe the're from China, TX...
- http://www.mapquest.com/maps/map.adp...China&state=TX -
Since you're in the central valley try giving Jim Dyer a call in Stockton to see what he carries. I have several sets from him that look and work nice.
Jim Dyer - Chevy Classics 209.941.2112
I also have put a drop of clear silicone under the clips where they meet the rim to keep them from moving. This works well and they come right off if you need them to.
Hope this helps;
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 6 (permalink) Old Jul 30th, 04, 04:15 AM
I have a set of repro rings with the 4 retainer original style clips. They are slightly thinner than original but otherwise they look/function great. Never had any issues with them. They realy bite down hard on the rims in my experience. Nothing on them that I could see that said "Made in ???"
If you want to know the vendor, send me an email.
-Mark.
stingr69 is offline
post #4 of 6 (permalink) Old Jul 30th, 04, 04:47 AM
Robert
I've bought good repro rings from Rick's and I've sent some back to Summit. I've also sent other stuff back to Rick's. I keep buying from both as well as other vendors because I've found that they all have parts that I may disapprove of from time to time. I always inspect them closely and install them promptly in case there is a problem. Stuff happens, send them back.
Robert
TC member #18
rojo is offline
post #5 of 6 (permalink) Old Jul 30th, 04, 06:35 AM
I have never had a problem with returning an item from Jeg's, Summit, and especially Rick's. I will say I have seen very poor quality from a lot of the suppliers to Jegs and Summit, and much better prescreening of parts at Rick's. Plus, Rick's will tell you up front in their catalog with some items not being up to the highest standards, but the best they can do presently until another supplier is found.
67 Camaro | 350 | 650 Speed Demon | Dual plane GMPP intake | MSD ignition | Secret Cam (I don't know what it IS!) | 2.02/1.60 Camel Humps ported | Thorley Tri-Y's | 8.5 10 bolt 3.73 | M22
jethro is offline
post #6 of 6 (permalink) Old Jul 30th, 04, 02:51 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Thanks for the replies (especially Vintage with China TX). I bought new trim rings at Wheel Vintiques here in town. They actually have the correct style with the correct lock. Only $80 per set if anyone needs a set. I suggested that they should wholesale to Rick's, D&R Classic and all others. They told me that they do sell to them. Go figure. If good products are available why would any dealer sell junk? Does a few dollars either way keep any of us from buying the best we can? [img]smile.gif[/img]
Gary L is offline
