275/40/17's on all four corners is done. - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 15th, 04, 04:52 PM Thread Starter
Carl
There's several here that have asked questions about fitting 275/40/17's on all four corners of my '68. There's now a new section on my website with pictures and text that shows the swap. Hopefully it explains most of the changes needed to make the fitment work.
If there's any questions please fire away.
CarlC is offline
post #2 of 5 (permalink) Old Oct 15th, 04, 05:34 PM
Jody
camcojb's Avatar
Exceeded your websites allowed useage. If this becomes a big problem I can host it for you. I'm very interested in what you did.
Jody
camcojb is offline
post #3 of 5 (permalink) Old Oct 16th, 04, 07:47 AM Thread Starter
Carl
Jody,
Geocities bandwidth limitations. One of these days I'll have to figure out how to write html and transfer everything over to my cable modem webspace.
Here's the text and pics from the website:
With a stock subframe? Yes. With stock A-arms? No. In the following section the installation of Speedtech A-arms is covered, and they are the key to fitting big rubber on the front of the car. The arms allow for more clearance of the rim and have a built-in steering limiter that makes adjustments easy. Some steering needs to be dialed out and the suspension rebound travel must also be limited to around 2.5" from ride height. This is with -1.8* camber. With less negative camber the clearances will be better (upper arm is the limiting factor) and will allow for more steering and rebound travel. The car needs to be on a track to determine the best track-only camber setting, but for the street a -1/2 to -1* setting should work fine. Steering is fine around town with the limited turning radius if care is taken to allow for a bit more turning room than normal. The rears require rolling the fenderlip from the 10-2 o'clock position if you have the stock full-width fenderlip. The fenderlip on this car is very wide and can be rolled fairly easily. The difference in cornering power is like night and day. Braking is much improved as well. The ride with the RII autocross tire is harsher than the more ballon-like BFG Comp T/A ZR 245/50/16's that were on the car, but it's well worth the tradeoff. The 275/40/17 size is the same as the C4 'Vette so availabity and compound choices are very good Due to the increased backspace of this rim it was necessary to slightly re-clock the flexible brake lines at the caliper for rim clearance.
The overall width difference of a 255/50/16 on an 8" rim vs. a 275/40/17 on a 9.5" rim is only 1/4" (275 is wider). However, the 275/40 lays down nearly 1.5" of additional tread width to the road. That's huge.
CarlC is offline
post #4 of 5 (permalink) Old Oct 16th, 04, 01:45 PM
Jeff
I would say that tread width difference depends on the brand tire you get. Some of the 255/50/16 tires are very close to the 275/40/17. It comes down to the brand of tire, width of the rim and what you're willing to spend.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, being restored
Jeff H is offline
post #5 of 5 (permalink) Old Oct 18th, 04, 01:47 AM
Rick
Carl, what's the tread width? Thanks much.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
