285/60/15's ?? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 6th, 04, 09:52 AM Thread Starter
Anyone running this size with little to no cutting? And what backspace?
I just got mine(AmericanRacer) and might have to do a little "trimming".
68 Camaro~LSx ~all motor
post #2 of 6 (permalink) Old Dec 6th, 04, 10:04 AM
67 Convertible's Avatar
I think the 285's would be too wide unless you trim or raise the rear. I tried 275-60-15 mounted on Cragar SS"s that a friend wants to sell me. I put one on the rear of my '67 a couple of weeks ago to test. I didn't drive it, it seemed to fit fine when just sitting. When bouncing on the rear bumper, I had about 1/2" clearance to the fender lip. Not sure if this is enough, particularly if someone was to sit in back seat. Just not sure if 1/2" clearance is enough. Any thoughts?
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #3 of 6 (permalink) Old Dec 6th, 04, 08:54 PM
Got 295\50\R15 BFGs on the rear of mine - minimal cutting......however,,,, rear shock are relocated inside the springs, stiff suspension, rims are 15x10 wheel vintique ralleys with a 6" offset......26.6" total height - I think your 285'a are like 28" or so? maybe a hair taller? - [img]smile.gif[/img]
Rat Touring 1969 Camaro X44 496 Richmond Super T10 Plus 4-Speed 3.55 4 wheel disc
..and sporting all new suspension, wheels, etc etc... take a look...
nick V is offline
post #4 of 6 (permalink) Old Dec 7th, 04, 05:22 AM
my 275's fit just fine, i think anything larger than 275 usually requires some cutting or rolling of the fender
aonghus is offline
post #5 of 6 (permalink) Old Dec 7th, 04, 07:23 AM
Bill
It really depends on the backspacing of the rims. My 275's stick out a bit, because the 8.5" rims only have ~3 3/4" backspacing.
WildBillyT is offline
post #6 of 6 (permalink) Old Dec 7th, 04, 10:15 AM Thread Starter
275/60/16 (28t x 10.8w)with 4.5"bs should fit fine. My 285's are SH tires(short)(27.4t x 11.7w) so I'm told,but a 285 should be 11.4. If I have to trim it isn't a problem.
