18" x 9.5" on 68 Camaro, backspacing? - Team Camaro Tech
post #1 of 21 (permalink) Old Dec 12th, 04, 12:02 AM Thread Starter
Roger
Aussie's Avatar
Is anyone currently running 18" x 9.5" rear rims on a 68 Camaro with a standard width rear and without any tubbing?
What backspacing are you running & what tire size?
Roger
68 SS RS Convertible
LS1 6 speed
Aussie is offline
post #2 of 21 (permalink) Old Dec 12th, 04, 02:58 AM
Matt
Roger,
I've got 17x9.5's on the front of my Chevelle that I tested on my '67 Camaro one day. They are 5.5" backspace, and they leave about 1/2" of clearance between the wheel tub and the tire. That is with drum brakes, if you have disks, it may give you a little more clearance. It will also depend on what size tire you run as well, mine was with a 275/40/17 which has almost 11" section width.
Bing
1923 T-bucket 406ci
1956 Chev 150 2dr sedan 302ci
1965 Chev Malibu 2dr hdtp 496ci
1967 Chev Camaro 327ci
2001 Harley XL1200C
2002 Chev 2500HD
2005 Chev 1500
2007 Harley FLSTC
post #3 of 21 (permalink) Old Dec 29th, 04, 06:49 PM
Yep, the standard MAX is a 275 tire on a 9.5" wheel w/ 5.5" b.s. when using a stock width axle and disc brakes...on a first gen.
awr68 is offline
post #4 of 21 (permalink) Old Dec 29th, 04, 09:06 PM Thread Starter
Roger
Aussie's Avatar
Thanks guys, Anthony is it the same for 17" & 18" rims?
Roger
LS1 6 speed
Aussie is offline
post #5 of 21 (permalink) Old Dec 30th, 04, 01:37 PM
what rim you looking at 18 9.50?
jigga99 is offline
post #6 of 21 (permalink) Old Dec 30th, 04, 06:23 PM
Yes Roger, it's the same for 17s and 18s...just the tire sidewall will be different between the two since you still want the same overall tire diameter...approx. 25.7" give or take...
awr68 is offline
post #7 of 21 (permalink) Old Dec 30th, 04, 09:26 PM Thread Starter
Roger
Aussie's Avatar
Jigga
Yes 18 x 9.5 rim, standard wheel wells & standard width rearend with discs.
Roger
LS1 6 speed
Aussie is offline
post #8 of 21 (permalink) Old Dec 30th, 04, 09:35 PM
I have a 17 x 9.5, 275 40 17 on my 67 and I have tire rub on the inside wheel well. Every car is a little different and depending on how low you want to go. It will make a difference. 67's and 68's are different than 69's because of the rear quarter design.
67RS RAG is offline
post #9 of 21 (permalink) Old Dec 30th, 04, 10:17 PM Thread Starter
Roger
Aussie's Avatar
67RS RAG
Do you know what the backspacing is on your wheels?
thanks
Roger
LS1 6 speed
Aussie is offline
post #10 of 21 (permalink) Old Jan 1st, 05, 06:51 AM
5.5 BS in rear and 4.75BS in front. Drums all around. I also have put 1/4" spacers on the rear to help but under hard accelaration and big bumps I get rub on the inside wheel well. Some others have the same problem and some get away with it. Like I said depending on how low you want your ride it can be avoided.
67RS RAG is offline
post #11 of 21 (permalink) Old Jan 1st, 05, 07:02 AM
with photos
67RS RAG is offline
post #12 of 21 (permalink) Old Jan 1st, 05, 01:11 PM Thread Starter
Roger
Aussie's Avatar
Thanks 67RSRAG.
Got any other pics you could send to me? Your car is a lot like where I'm hoping to get mine to, mine is a 68RSRAG [img]graemlins/thumbsup.gif[/img]
Roger
LS1 6 speed
Aussie is offline
post #13 of 21 (permalink) Old Jan 2nd, 05, 02:39 PM
Rob
67RS Rag, what size tires do you have on the rear? Even with the 1/4" spacers, do you still hit on the inside of the tire, or just on the outside now?
Thanks!
Rob
Rob Rice
RobR is offline
post #14 of 21 (permalink) Old Jan 2nd, 05, 05:19 PM
Aussie let me know if there is something specific you are looking for and I will be happy to send you some.
Rob, I have 275 40 17 on the rears and with the spacers I am still hitting on the inside wheel but not on the outside
67RS RAG is offline
post #15 of 21 (permalink) Old Jan 4th, 05, 07:07 PM
Rob
I have 255 on the rear with 9.5 inch wheels and 5.5 backspacing. I bought 1/4 spacers a couple of weeks ago, but have not installed them yet. I also don't like the look of the 255 and want to replace them with 275 or 285/40. Your rear wheels are 9.5?
Rob Rice
RobR is offline
