69 Rallys 15x7 - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 17th, 04, 09:42 AM Thread Starter
I tried this in Chevelle Tech and didn't get much help, thought I'd try it here.
I found a set of 15X7 69 rally wheels that the owner says he took off of a 69 Z28, says they are a matched set. I can come up with the correct numbers that should be on these from Chevy by the Numbers.
Question, if they are in decent shape (no rings or caps included) about what should I expect to pay for them. He wants $160. I'm going to get them or look at them Tuesday.
Chris
ccarney69
69SS Chevelle 396/350 NC8 Stock/Original/Survivor
65SS Chevelle 283/195 Stock/Original/Survivor
64SS Chevelle Convertible 283/220 4 speed (next project)
65 GTO Convertible 389/360 4 speed (restored)
65 Impala 327/300 Stock (current project)
67SS Impala 396/325 Survivor
65 Grand Prix, the cruiser!
Team Chevelle #2337
ccarney69 is offline
post #2 of 9 (permalink) Old Dec 17th, 04, 10:12 AM
With the trim rings and center caps? If so you would be stealing them. If they don't have them and they match the date of your car they are still cheap. YH coded wheels will probably run you $100 plus each normally.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 9 (permalink) Old Dec 17th, 04, 12:41 PM Thread Starter
He said he had found three of the trim rings and no center caps. I dont expect the rings to be in useable condition but hope the rims are still good.
They should be the YH or the AD wheels, is that correct.
Chris
post #4 of 9 (permalink) Old Dec 17th, 04, 03:28 PM
DF are early 69 AD are mid 69 wheels, YH are mid and late 69 wheels. Think DF's were only used for about a month of 69 production, then AD till January or so, the YH for the rest of the year. So I guess it depends on when your car was made. YH are the most common wheels though. Those dates are rough, as I don't follow Z28 wheel use since I don't have a Z.
[ 12-17-2004, 06:39 PM: Message edited by: Mark C ]
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 9 (permalink) Old Dec 18th, 04, 06:27 AM
William
William's Avatar
DFs are 15 x 6 67-68 Z/28 wheels; never used on 69s.
Sharp YH wheels dated correctly for Yenkos can easily cross $1000/set. They were used into the 70 model year on Monte Carlos; 70 dates have little value. AD wheels are uncommon but do not command the same prices. Later FW wheels are dimensionally identical to YHs but are quite common and nearly sale proof.
William
CRG
William is offline
post #6 of 9 (permalink) Old Dec 18th, 04, 07:15 AM
Guess we should change the table here then:
http://www.camaros.org/suspen.shtml#Wheels
1969
Steel Drum
FC 14x6 inch Base
Steel Front Disc
XF 14x6 inch Base
XT 14x7 inch SS
Rally Drum
XN 14x6 inch Base
Rally Front Disc
XG 14x6 inch Base
YJ 14x7 inch SS
DF 15x6 inch Z28 (early)
AD 15x7 inch Z28 (middle)
YH 15x7 inch Z28 (late)
RPO N66 Front Disc
YA 14x7 inch SS (early)
AO 14x7 inch SS (late)
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #7 of 9 (permalink) Old Dec 18th, 04, 07:39 AM
William
William's Avatar
We should.
Years ago someone speculated that early '69s used DFs. It got into print has been repeated so many times it has been accepted as fact.
The fact is to date no documented '69 Z/28 is known to have been built with DF wheels and there are several excellent original early production cars in existance.
I know of a 68 Z/28 built with 14 x 6 wheels. Maybe that should be on the chart.
William
CRG
William is offline
post #8 of 9 (permalink) Old Dec 29th, 04, 12:17 PM Thread Starter
Turned out to be FW, 71 to 75 Monte Carlo or Chevelle 15x7s.
Chris
post #9 of 9 (permalink) Old Jan 6th, 05, 05:59 PM Thread Starter
Decided to check out a set of rallys that came on a 65 chevelle that I bought. Thought they would be corvette rims since seller said thats what they came off of.
Turned out to be 69 15X7 YH wheels, they are in real nice shape and have trim rings and center caps that are also very nice.
Is there any way to determine if the rings and caps are correct for the wheels.
Chris
