15 X 7 Rally wheels - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 20th, 04, 04:49 PM Thread Starter
My 68 convertible came with 14" wheels and hubcaps from the factory but I bought some 15 X 7 rallys to put on. Does anyone know of any reason why these would not fit. Car is all stock with no mods.
68RSdroptop is offline
post #2 of 8 (permalink) Old Dec 21st, 04, 04:27 AM
Will
They'll fit, no problem
wilmarwil is offline
post #3 of 8 (permalink) Old Dec 21st, 04, 05:03 AM
67 Convertible's Avatar
The "wheels" will fit fine. You make no mention of the size tires you will be mounting...the higher and wider you go, the more risk of rubbing.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #4 of 8 (permalink) Old Dec 21st, 04, 10:03 AM Thread Starter
Thanks,
Can anyone reccommend a good tire size for these wheels, that will not rub but will look nice and meaty on the road?
post #5 of 8 (permalink) Old Dec 21st, 04, 10:34 AM
255/60/15 rear, 235/60/15 front
kz1000ltd is offline
post #6 of 8 (permalink) Old Dec 21st, 04, 10:35 AM
Most folks can run 245 or 255 60's on rear, 225 or 235 on front. If you want equal size around a good size is 235's all the way around for a meaty look. Do a search on the site..the size question has been beat back and forth for years now. Jee Kz, just beat me to it
Tony67SS is offline
post #7 of 8 (permalink) Old Dec 21st, 04, 03:38 PM
IF YA GOT THE FACTORY STOCK SUSPENSION I RECOMMEND YOU PUT A PAIR OF 235/60 ON THE FRONT WHEELS , THEN CHECK ALL CLEARANCES & IF OK LEAVE AS IS & INTALL 245 ON OTHER PAIR!! IF RUBBING OCCURS THEN PUT THAT PAIR OF 235 /60 ON THE REAR OF CAR OF WHEELS & THEN INSTALL 225/60 ON THE OTHER PAIR & INSTALL THEM ON FRONT.
Rick Stewart is offline
post #8 of 8 (permalink) Old Dec 21st, 04, 04:47 PM
jake bohannon
235/60 rear
215/60 front
I put some cooper cobras on the look and ride great, this tire is a "handling type tire" really grabs the road.
:href="http://home.mchsi.com/~jakeman23" target="_blank">http://home.mchsi.com/~jakeman23</a>
1stGenJake69 is offline
