285/60/15's on .... - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 31st, 04, 09:48 AM Thread Starter
Just got tires mounted, what a pain! I got home and put right on with no problems. They are close, maybe .5 - .75 (a finger), but no mods and no rubbing.
[img]graemlins/hurray.gif[/img]
*pics just uploaded, might be 24 hours till you can see?
68 Camaro~LSx ~all motor
post #2 of 11 (permalink) Old Dec 31st, 04, 01:23 PM Thread Starter
doubled up...whooopppsss
[ 12-31-2004, 04:43 PM: Message edited by: DOUG G ]
post #3 of 11 (permalink) Old Jan 2nd, 05, 03:10 AM Thread Starter
post #4 of 11 (permalink) Old Jan 10th, 05, 09:14 PM
Jack
Doug I guess that if the 285/60/15 fit I should be OK with a set of 275/60/15 Mickey Thompson drag radial's on 15/8 Weld Racing wheels, on my 67 Right?
67 Camaro Street car 3300 lbs
Flat Top 406 70cc Edelbrock RPM Heads
Q-jet comp xe268s 2500 stall converter
T-350 12 Bolt Posi 373's Cal-Tracs
60' 1.69
330' 4.950
660' [email protected]
1320' [email protected]
Fast Jack is offline
post #5 of 11 (permalink) Old Jan 11th, 05, 04:19 AM Thread Starter
Jack 4.5" back space ? then absolutely.
The 285's I'm running are American Racers and are SHT's (short) 27.4x11.5 so they are close and at full droop hit the shocks.No big deal IMO.
post #6 of 11 (permalink) Old Jan 11th, 05, 04:31 AM
Jody
camcojb's Avatar
Just realize that they will not tuck up into the wheelwell in that size and backspace. So your car has to be high enough in the rear to never come down on the tire.
Jody
camcojb is offline
post #7 of 11 (permalink) Old Jan 11th, 05, 06:58 AM Thread Starter
I have about 3" or so between top of tire and wheelwell. Haven't got to "test launch" yet , but doubt the rear will sink 3+".
post #8 of 11 (permalink) Old Jan 11th, 05, 10:46 AM
I put welds on my 69 friday 15x8-4.5 bs.275x60x15 ta radial my body is sitting perfect(side to side) on the body mounts,and my car sits low(mono spring)I have about 2.5 or 3 inches of tire up in the fender well it wont rub going up and down but put in a bind they will scrub.I'm giong to roll the outer fender lip.I would post pics but I dont know how(computer illeterate!!)
georgia 69 is offline
post #9 of 11 (permalink) Old Jan 12th, 05, 04:05 AM Thread Starter
67 & 68's are round wheelwells and 69's are squared off. Thats where/why they tuck.
post #10 of 11 (permalink) Old Jan 14th, 05, 11:08 AM
How can I get a look at these tires? Is there a web site I could go to or did you buy them direct?
A Civic with a turbo the size of your head at 10,000rpm will never sound as impressive as a blown big-block at idle.
Dave_Rivera is offline
post #11 of 11 (permalink) Old Jan 15th, 05, 03:09 AM Thread Starter
I got mine from http://www.americanracetires.com/index.html but it only shows sizes. I did a search on American Racer tires and found a lot of links. Had one of them send lititure, showed size and tread. Mine have the GG tread.
