18&9.5 - 18&9 or 10 wheels - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 6th, 05, 08:02 AM Thread Starter
ive been looking for wheels for the last 2 months and all the wheels i find are 18-9 or 18-10 so if i go with 18-9 with a 275 tire is the backspacing still 5.5? do you think i can fit a 10 with out mods?
jigga99 is offline
post #2 of 6 (permalink) Old Jan 6th, 05, 03:56 PM
How much rubbing do you want to live with? All joking aside depends on serveral factors - the car for 1 - the tire size and series - disc brakes - ride height - how much weight will be in it. 275 is the max tire size and on lowered cars several people here had rubbing issues - on the inside. People have gone with 255 tires to stop it. On www.pro-touring.com under the 69 Camaros look at Rich Downing's car that has 18x10s with 5.75" backspace and 285/35-18s and he said they rubbed bad! On the inside - so much so he used a 1/4" spacer to create a 5.5" backspace to calm it down. His conclusion was "there is just not enough room in there for a 10" wheel". My point is you can get them on there but they will probably rub somewhere. Do you want to put up with it? I say go with the 18x9s but that's up to you. Good Luck - Jack
Jack
JV69z/28rs is offline
post #3 of 6 (permalink) Old Jan 7th, 05, 08:08 AM Thread Starter
thanks jack i think you helped me make up my mind, im going 18-9 back 275/40/18 17-8 245/45/17
got drums all the way around but not for long, and want to lower it as low as posible, so you think 5.5 bs in the back is the best bet?
jigga99 is offline
post #4 of 6 (permalink) Old Jan 7th, 05, 07:45 PM
There is a couple of schools of thought on that. 1 is to go with the 5.5" backspace and if need be you can always use a 1/4" spacer to move the wheel out. Of course you can't move the wheel the other way. The other is that if 5.5" is good for a 9.5" wheel than 5.25" is good for a 9" wheel. Split the difference. I say check your car - both sides by the way - and make your choise. Better to error on the inside though because a spacer is always an option. Jon from Budnik wheels has a '69 Camaro and he has 18x8s in the front with 4.75 backspace and a 235/40-18 tire - in the rear he has 18x9s with 5.375 backspace and a 275/40-18 tire with no disc brakes. The car is low and he has NO clearence issues at all. He also has tried this combo on a car with Wilwood rear dics and had no clearence issues. You can see the car at www.budnik.com in the gallery - it's the blue '69 without the white stripes. Good Luck - Jack
Jack
post #5 of 6 (permalink) Old Jan 8th, 05, 10:00 AM Thread Starter
really good info jack whats the best way to measure back spacing, i want to lower it too so i guess i got to get it right the first time
jigga99 is offline
post #6 of 6 (permalink) Old Jan 9th, 05, 04:16 AM
Try this www.chevyhiperformance.com/techarticles and go to page 9 - next to last article on the bottom of the page - Fat On All 4s. I think you can get the answers to all your questions there. Just keep in mind that those 20s don't really fit and the Camaro in the article has narrowed control arms. The measuring and backspace info is good. Sorry I don't know how to link it. Hope that helps - Jack
Jack
