17" Trim Rings - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 11th, 05, 11:05 AM Thread Starter
I'm in the process of purchasing some 17" Ralleys and now find out that 17" trim rings are not available.
I did some time ago read a post about using 17" VW rings, does any one have information on that?
Is there a company making 17" rings ?
RickM is offline
post #2 of 7 (permalink) Old Jan 11th, 05, 11:44 AM
The only 17 inch ralleys I've ever seen are billet and do not require a trim ring,Who makes the wheel you are looking at?
georgia 69 is offline
post #3 of 7 (permalink) Old Jan 11th, 05, 02:33 PM
I actually called Wheel Vintiques the other day with the same question. They said that unfortunately right now they do not have a supplier or know of a supplier for the 17" trim rings.
king67rsss is offline
post #4 of 7 (permalink) Old Jan 11th, 05, 03:24 PM
67 Camaros Rock
Joe Harrison's Avatar
I saw some that were custom made, cut welded in a piece then cromed. Looked good but I was told they cost $400.00 to make!!! B/S I don't know but they were cool.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #5 of 7 (permalink) Old Jan 12th, 05, 08:53 AM
How about a fullsize truck with 17" steel wheels. Maybe some of these came with rings, but the probably would be 2 1/2" or less.
sicsD8 is offline
post #6 of 7 (permalink) Old Feb 8th, 05, 11:15 AM
Hirsch Auto
Try these guys, they have 17" trim rings, they're reproductions to fit vintage Packards so they're not GM style nor are the very wide but they appear to be very high quality and NOT cheap.
Hippie is offline
post #7 of 7 (permalink) Old Feb 8th, 05, 11:28 AM Thread Starter
Good Information Thank You will check it out
RickM is offline
