14" rally question - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 10th, 05, 09:47 AM Thread Starter
Does anyone know if the backspacing is different between the 14 x 6 and 14 x 7's. I guess what I want to know is the extra inch on the outside, inside or half of each?
sicsD8 is offline
post #2 of 3 (permalink) Old Mar 11th, 05, 08:03 AM Thread Starter
bump^^ anyone??? big swap meet coming up sunday. Would like to know by then.
sicsD8 is offline
post #3 of 3 (permalink) Old Mar 13th, 05, 12:19 PM
Jeff
Not all 14x6's are the same, and not all 14x7's are the same either.
Different applications used same size wheel, with different backspacing.
Use "Chevrolet by the numbers" for the wheel codes to determine which is which.
However, unless you are using a much larger tire, I doubt any would be a problem.
Pacecarjeff is offline
