CORRECT SIZE TIRES - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 17th, 05, 05:05 PM Thread Starter
I READ ALL THE POSTS ON WHEEL AND TIRE COMBOS,AND I DID NOT SEE WHAT I'M ABOUT TO ASK.
I JUST DID A COMPLETE NUT AND BOLT ORIGINAL RESTORATION ON A 69 CAMARO 427 435HP TRI POWER 4SPD.WITH FRONT DISK .CORRECT FRONT AND FIVE LEAF REAR SPRINGS.I WANT TO USE A 14X7 GOODYEAR RADIAL TIRE UP FRONT BUT I'M NOT SURE WHAT SIZE WILL LOOK AND FIT BEST.OR,WOULD A 14X6 WORK AND LOOK BETTER ??
CAN ANY ONE OUT THERE IN CAMARO LAND FILL ME IN ON THIS??
THANK YOU,AND THANKS TC
rocks34 is offline
post #2 of 2 (permalink) Old Mar 17th, 05, 05:59 PM
I have a 68 camaro, so I'm not sure if there would be any difference on the tire sized that you can run, but I had 245/60/14's all the way around on my car at one point but now i have 225/60/15's on the front and 295/50/15's on the back. The rim size is a 15x8 and it gives it a pretty good stance. Hope this may help out a little
Travis
TravisTco is offline
