tire size - front & back - Team Camaro Tech
 8Likes
post #1 of 21 (permalink) Old Mar 20th, 16, 06:01 AM Thread Starter
I have a '68 with stock 14" rims. I'm switching to 15x7 inch in order to put front disc brakes on and also put on a larger tire. I was thinking of going to a 215/70 in the front and a 255/60 in the back as the height is close to the same. If I go to the 225/70 in the front, the front would be higher than the back of the car. Anyone running with 215/70 in front and 255/60 in the rear? If so, do you have any pictures.
Thanks much.
Troutslayer is offline
post #2 of 21 (permalink) Old Mar 21st, 16, 01:12 AM
Garth
Re: tire size - front & back
Most 67/8 guys with 15" run either 225/60 or 215/65 in the front. The space between the tire and wheel well is almost always greater in the rear (depending on the suspension and load), so a slightly taller tire in the back helps even out that gap.
Garfields Maro is offline
post #3 of 21 (permalink) Old Mar 30th, 16, 02:50 PM Thread Starter
Thanks. After everything i've read, I'm going to go with 235/60 15's all the way around. That way I can rotate as needed. Thanks for the reply though.
post #4 of 21 (permalink) Old Mar 30th, 16, 10:28 PM
Garth
You might have some rubbing in the front...?
post #5 of 21 (permalink) Old Mar 31st, 16, 04:19 AM
Here's my '69 with 215/65-15 on 15x7 rims. Same size tire/rim on all 4 corners. In the right conditions, I get tire rub on the front, but hopefully that is cured in the next week as new front springs are going in to get the car level.
[IMG][/IMG]
68Tiger likes this.
buenymayor is offline
post #6 of 21 (permalink) Old Mar 31st, 16, 01:10 PM Thread Starter
After reading all the posts and threads/information, I was told the 235's won't rub. That's why I went with the smaller diameter 60's instead of 65's or 70's. I hope I'm right. BTW, your car looks great.
post #7 of 21 (permalink) Old Mar 31st, 16, 03:00 PM
Garth
235/60 on the front of a 67-8 is borderline. Depends on the suspension, wheel backspace, etc...
post #8 of 21 (permalink) Old Apr 1st, 16, 10:33 AM Thread Starter
Took your advice. Going with 225's in the front and 235's in the back. Thank you!!!
Kilr67 and 68Tiger like this.
post #9 of 21 (permalink) Old Apr 1st, 16, 09:06 PM
Dan
Old picture but this is 215/65/15 front on 15x7 and 255/60/15 rear on 15x8, soon to make a return on my convertible.
68cvb, 68Tiger and Troutslayer like this.
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
post #10 of 21 (permalink) Old Apr 2nd, 16, 07:07 AM Thread Starter
Great looking car.
post #11 of 21 (permalink) Old Apr 6th, 16, 03:30 AM
Dom
68Tiger's Avatar
X2
I run BF Goodrich Radial TA 225/60/15 on front and 235/60/15 on rear. Car has a 1-1/2" drop and I have no rubbing issues.
68Tiger is online now
post #12 of 21 (permalink) Old Apr 7th, 16, 11:54 AM Thread Starter
Awesome. Thank you! Great looking '69 as well.
post #13 of 21 (permalink) Old Apr 26th, 16, 01:23 PM Thread Starter
Here's how she looks now. 15x7's. 225/60's in the front, 235/60's in the back.
Rarerat likes this.
post #14 of 21 (permalink) Old Apr 26th, 16, 03:28 PM
Andrew
Andrew69's Avatar
Looks great!
Troutslayer likes this.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #15 of 21 (permalink) Old Apr 26th, 16, 07:02 PM
I'm looking at a few '69's and wondering about wheels... trying to decide if I like the muscle look or the pro-touring look. I'm not a purist and will never buy a numbers-matching car, so I'm more concerned with what rubber will fit without rubbing with basically stock suspension or maybe slightly lowered. Also sucks that most aftermarket 15" wheels only come in 8" or 10" widths and not half-inch increments LOL. Guess theres always Vintique wheels?
But for a typical rear 15" by 8" Rally wheel or a Cragar SS wheel... what sizes and profiles will fit?
And for a typical rear 17" wheel... with maybe a 8-9-10" width... what works?
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
