wide front wheels - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 1st, 16, 05:16 AM Thread Starter
Matt
wide front wheels
I got a couple question that I am more or less just curious about and hoping you guys could help.
what is needed to fit a 9.5" wheel with a 275 tire on the front of a 1st gen?
I was reading about ridetech tru-turn that claims it can fit up to a 10" wide wheel but requires their spindle.
So when I get a car I am thinking now about just doing the c5 brakes front and rear. But kore3 bracket requires you use a front drum spindle that is not compatible with the ridetech tru-turn. I believe the ridetech spindle accepts stock front disc setup.
The question is can you do c5 brakes with a disc spindle? And I guess other that the tru-turn setup you would have to go with a custom sub-frame.
Any and all info would be greatly appreciated, I tried to search but didn't come up with a lot of helpful info.
Currenty dreaming....currently busting butt getting ready to fulfill that dream.
01m6ta is offline
post #2 of 5 (permalink) Old Apr 1st, 16, 05:27 AM
Re: wide front wheels
Ridetech spindles are affordable. I have a Tru-turn setup with their spindles and Kore3 hubs and brackets.
dhutton is offline
post #3 of 5 (permalink) Old Apr 1st, 16, 06:02 AM Thread Starter
Matt
ok cool so you can use kore3 brackets with the ridetech spindles.
what size wheels and tires are you running up front?
thanks
01m6ta is offline
post #4 of 5 (permalink) Old Apr 1st, 16, 06:10 AM
thanks
It is a project in process. You can run up to 10 inch if you can tolerate a little rubbing but 9.5 is safer. At least that is what I have found in my research. I'm not too concerned about running a wide tire up front for this project. It's a 69 vert that I am building for my wife so no minitubs (hassle with a convertible) and no need for 10 inch wheels up front since the rears will be 9.5 or 10 inch. I went with the Tru-Turn for the steering geometry improvements.
My other project is a 69 for me and it has an AME subframe. I am running a 295 tire on a 10 inch wheel with the help of some Anvil fenders and inner fenders to go with the 345 tires on a 12 inch wheels on the matching AME IRS.
dhutton is offline
post #5 of 5 (permalink) Old Apr 1st, 16, 06:14 AM Thread Starter
Matt
gotcha, yeah I was thinking of it just to have a square setup, 9.5" with 275's on all four corners. not really a fan of staggered look.
01m6ta is offline
