Torque Thrust Question - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 10th, 16, 05:27 PM Thread Starter
Im looking at these rims for my 67 camaro;
VN3097861 17" x 8" 5x120.65 0 4.50 VINTAGE SILVER W/ MACHINED LIP 83.06 1580 lbs $260 1055001
Will the 4.50 BS be an issue for 235,245,255/45 for the front. I plan to the same wheel and tire size on all four.
ra11eysport is offline
post #2 of 6 (permalink) Old Apr 11th, 16, 06:56 AM
George
Gbauer's Avatar
Re: Torque Thrust Question
I'm running 17x7 TTII's with a 4.02" back space and 225/45-17 tires on the front of my 68. Under extreme compression I do get a bit of rubbing on the front. I'm lowered about 1.5" up front.
I think you'll be a lot better off to go staggered. Save the 17x8's for the back with some 255's and do the 17x7 up front.
It's a weekend car. Not a daily driver. You'll likely find that the tires need to be changed because of age faster than wear.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 6 (permalink) Old Apr 11th, 16, 01:27 PM Thread Starter
Thanks Gbauer,
Its going to be a daily driver its my only other car besides the work van! Right now i just put on Hotchkis a arms and 2in drop springs and some wilwood superlites with 13in rotor. Here this summer im getting a LS3 crate motor and a TKO600. The reason i dont want to run staggered is, one the look is not for me and also my 12 bolt is a half inch longer than stock. So with rear disc brakes i want to keep the rear tire with in the lip of the wheel well. Plus i like the balanced look of the same size tires.
post #4 of 6 (permalink) Old Apr 11th, 16, 01:40 PM
Brent
67Rally's Avatar
You can probably get away with 235/45/17's with those. A 245 is probably going to be close to the fender, and a 255 will almost definitely be a problem with a 2" drop on a 17x8 w/4.5"BS. Ideally you'd like to have 4.75" bs on an 8" wide wheel, which would buy you an extra 1/4" of clearance, and allow you to run a 10mm wider tire.
67Rally is offline
post #5 of 6 (permalink) Old Apr 11th, 16, 01:43 PM
George
Gbauer's Avatar
Originally Posted by ra11eysport View Post
Thanks Gbauer,
Mine don't stick out. 17x8 rear with 4.57" back space. 17x7 front with 4.02" back space.
Technically not TTII's. They're a special edition which means fancy paint and center caps.
http://www.tirerack.com/wheels/Wheel...8&autoModClar=
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 6 (permalink) Old Apr 11th, 16, 01:54 PM Thread Starter
American Racing Authentic Hot Rod AR105 Torq-Thrust M Anthracite w/Mach Lip
Thanks that helps alot! Looks i can do 245's on all four cause the rims i want are 17x8 4.5BS so that should help on the fronts. I just really like a wide front tire.
Nice ride!!
