1968 Camaro Stardard Wheel size - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 16th, 16, 09:35 AM Thread Starter
Lee
I have 1968 standard Camaro with a 327 V8 that I am restoring.
I am not modifying the suspension it will be all standard.
I currently run 14" stock tires. Can I run a 15" tires without any issues, like rubbing the body?
What size could you recommend?
Lee
Reggiecamaro1968 is offline
post #2 of 4 (permalink) Old Apr 16th, 16, 02:30 PM
Re: 1968 Camaro Stardard Wheel size
Are you looking for one size all the way around or big and littles ?
https://www.camaros.net/forums/17-whe...re-combos.html
68 Camaro~LSx ~all motor
post #3 of 4 (permalink) Old Apr 17th, 16, 11:24 AM Thread Starter
Lee
Just one size all the way around. Thanks
post #4 of 4 (permalink) Old Apr 18th, 16, 12:54 AM
Garth
Size limitations will be determined on the front tires. A 225/60 x15 is about as big as you can safely go in the front on a 67/68 with stock suspension. 215/65 is slightly taller and narrower and works fine as well. This is on a 15x7 wheel (rally wheel) with 4.25 " back space.
Here's a spec sheet from BF Goodrich so you can compare the different sizes...http://www.monro.com/datasheets/BFGo...-Radial-TA.pdf
Garfields Maro is offline
