Disc hubs - Team Camaro Tech
post #1 of 6 (permalink) Old May 10th, 16, 04:23 AM Thread Starter
Disc hubs
I changed my front spindles from drum to disc. Has that changed my backspace requirement? I may wind up with wheels for the car before I get fenders hung on it and hopefully will avoid a surprise.
3d cad is offline
post #2 of 6 (permalink) Old May 10th, 16, 08:06 AM
George
Gbauer's Avatar
Re: Disc hubs
Not much but it will push it out about 1/4" or so.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 6 (permalink) Old May 10th, 16, 05:23 PM
Re: Disc hubs
Not to hijack the thread but what about the rears? If you go to 4-wheel discs, will the rear move out 1/4" as well? Is that because of that 3-hole bracket?
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #4 of 6 (permalink) Old May 10th, 16, 05:36 PM
George
Gbauer's Avatar
Re: Disc hubs
No idea on the rears.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 6 (permalink) Old May 10th, 16, 06:13 PM
Re: Disc hubs
Most guys find the difference in the new rotors bearing depths but as mentioned , its usually not much.
TC # 349
zdld17 is offline
post #6 of 6 (permalink) Old May 10th, 16, 07:11 PM Thread Starter
Re: Disc hubs
With the car in the shop I have little to do other than obsess over details. After I get it back I will soon be in the position of having to make something fit in the back which leads right into what fits in the front. Not a problem if you are close to stock but it's an issue with stagger. I fit my front end out with a C-5 conversion 12 years ago and then left it sit never looking into whether or not the change affected my offset. Depending on the wheels looked at a quarter inch can be just too far. More stuff to sweat over.
3d cad is offline
