Tubbed 68 Camaro- Need tire advice - Team Camaro Tech
post #1 of 5 (permalink) Old May 19th, 16, 05:35 PM Thread Starter
nick
Hey everyone~
I have a tubbed 68' that I'd like to do a different set up on. Right now, the car has 18.5 inch wide Mickey Thompsons on the rear with standard skinny drag radials in the front.
I'd like to go to a narrower tire- maybe a 12-14 inch? I'm going for more of a pro touring look, without the low profile tires- I'd like to keep the old school look of the car and stay away from the Foose style rims.
The reason I'm changing is mainly because I do not like the way the rear tires perform on the highway and how the wash out a bit when the car corners. They also squeal like crazy when I am parking the car so if a different tire size helps with this issue I'm all about it.
I have a 9 inch Ford rear end in the car with adjustable shocks- I'd like to maybe do a different offset so that the tires stick out a bit more rather than being hidden under the fenders. Would this require setting up leaf springs or taller shocks?
Any suggestions are appreciated.
unclenick is offline
post #2 of 5 (permalink) Old May 19th, 16, 06:31 PM
Re: Tubbed 68 Camaro- Need tire advice
What MT tires you running ?
I know when I was running bias ply tires they liked to track cracks in the road ECT...kind of squirmy
68 Camaro~LSx ~all motor
post #3 of 5 (permalink) Old May 19th, 16, 06:41 PM Thread Starter
nick
I think I'm running the Sportsman Pro- here is a similar tire that has the exact same tread and sidewall. Mine are 18.5 wide
http://www.jegs.com/i/Mickey+Thompso...o3YBoCLI_w_wcB
post #4 of 5 (permalink) Old May 19th, 16, 07:22 PM
Gary
MangeMD's Avatar
Are they squealing like crazy because your rear is spooled?
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #5 of 5 (permalink) Old May 20th, 16, 02:49 AM
I would try a radial and I think you'll be surprised.
Also, as above...does it have a spool ? I know I'll get a few chirps if I turn too tight with mine.
