Centerline Wheel Measurements - Team Camaro Tech
post #1 of 7 (permalink) Old May 29th, 16, 09:30 AM Thread Starter
Cody
Question Centerline Wheel Measurements
Does 8 1/2"x15" with 4 3/4" Backspace sound like a typical measurement of a Centerline wheel from the 1970's somebody would of had on their street/strip '69 Camaro? Centerline's website shows for the 8 1/2"x15" a PN for 4 7/8" Backspace.
I am restoring my Dad's old 1969 base model Camaro that he used to daily drive/race. I am keeping the Centerlines and am starting to look for tires for it while retaining the stock wheel wells and height.
Will I run in to problems running a 275/60/R15 tire (28" tall), or do I need something shorter like a 275/50/R15 (26" tall)?
Thanks for the help,
Cody
[IMG]
[/IMG]
ceager is offline
post #2 of 7 (permalink) Old May 29th, 16, 10:28 AM
Steve69SS396's Avatar
Yes, that was a size available and I believe still is now. I ran 275/60/15's on 10" wide Centerlines with 4-3/4" back space. I did have to roll the outer lip to clear and trim the bump stops on the rear subframe. With an 8-1/2" rim it will clear easier. Do a search on here and you should find a thread from Fred putting the same size tires on his '69.
Steve69SS396 is offline
post #3 of 7 (permalink) Old May 29th, 16, 02:53 PM Thread Starter
Cody
Re: Centerline Wheel Measurements
Steve,
Thanks for the help. I will look for Fred's post, what is his username?
I was just curious since many of the 69's on here on a 275 tire run a 40 series, which I guess is just the safer route.
Thanks again,
Cody
ceager is offline
post #4 of 7 (permalink) Old May 29th, 16, 06:41 PM
Lynn
I have 15 x 8.5 with 4.5 back spacing. I installed Hoosier 275 60 15 drag slicks. They did not interfere with the car sitting still, but were so darn close, I was afraid to drive it. Just the slightest movement, and I would have rubbed the newly painted quarter. Still had clearance on the inside, bit it was also close. I chickened out and installed 255 60 15 in the rear. Good compromise. Fits well up under the wheel wells, and no rubbing going around corners. Sold the Hoosiers for a loss (lose a little on each deal and try to make up the diff with high volume).
The same size tire in another brand might have been OK. These tire size markings are not exact on width and aspect ratio. There is some variation from one brand to another, and even one model to another within the same brand.
Having said that, I cannot imagine that Steve actually ran 275's on a 10 inch centerline with 4 and 7/8 back spacing. That would leave 1 and 1/8 inches farther out for the outside of that rim than my 8.5 wheels. I just don't see how that wouldn't rub, even sitting still, even with rolled outer lip. Maybe rolling that outer lip gained that much space. Seem like a lot of rolling. Not calling Steve a liar by any means. Maybe the 275 he ran was that much smaller than my Hoosier tire. Or maybe it had a little more back spacing, or was in fact an 8.5. Memories fade.
Bottom line is: if you want to be safe, go 255 60 15 on that 8.5 wheel.
Lynn
bilodeaulynn is offline
post #5 of 7 (permalink) Old May 30th, 16, 10:03 AM Thread Starter
Cody
Bilodeau,
Thanks for the info. My old man "clearanced" the wheel wells a little bit at some point. I think I'll be able to squeak by with the 275's after a bit of research and measuring.
Thx,
Cody
Sent from AutoGuide.com Free App
ceager is offline
post #6 of 7 (permalink) Old May 30th, 16, 05:40 PM
Lynn
I think you are probably OK if there has been some work back there. My car had just been painted and I didn't want to take a chance of rubbing.
Good Luck.
Lynn
post #7 of 7 (permalink) Old Jun 11th, 16, 05:06 PM
Originally Posted by ceager View Post
Steve,
Thanks again,
Cody
Been on vacation. Posted my first response from my phone. Not sure how to search with it. Fred Ficarra: https://www.camaros.net/forums/17-whe...-you-guys.html
