Foose wheels rubbing - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 13th, 16, 11:00 AM Thread Starter
Frank
I have 17" Foose wheels Legends, I installed a Ride tech streetgrip suspension which lowered the front approx. 2" now the outside edge of tire is rubbing the inside edge of ender when it compresses. the hubs look like there is a ton of material there, was hoping i could get local machine shop to mill some off the backside? Just trying to get some opinions
Thnx, Frank
one fine SS is offline
post #2 of 7 (permalink) Old Sep 13th, 16, 12:41 PM
jim
Re: Foose wheels rubbing
17" wheels but how wide and tire size
68cvb is offline
post #3 of 7 (permalink) Old Sep 13th, 16, 01:52 PM
Ty
69&76's Avatar
I have a 69 with 18"Foose with 2"drop in front. My front tires rub a bit, but only when I make a full turn on the steering wheel, otherwise they tuck in nicely. I think I have a 4.5" off-set.
69&76 is offline
post #4 of 7 (permalink) Old Sep 13th, 16, 01:58 PM
Check your alignment. Shoot for -.5 deg camber and you will likely be fine...
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 7 (permalink) Old Sep 13th, 16, 03:58 PM
Larry
larryh56's Avatar
Have you installed aftermarket disc brakes? I had the same problem with the same wheels because the hubs for the disc brakes moved the wheels out by about 9/16". CPP came out with a hub that moved the wheel almost back to the stock location and there have been no more rubbing issues.
How do you like your Streetgrip suspension package?
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #6 of 7 (permalink) Old Sep 13th, 16, 05:42 PM Thread Starter
Frank
Yes I do have aftermarket 4 wheel discs. I'll have to look into the hubs.
I definitely like the Ridetech suspension, still playing around with the shock settings.Huge improvement though !!
post #7 of 7 (permalink) Old Sep 13th, 16, 05:47 PM Thread Starter
Frank
17x7 Foose Legend 5x4.75 bp. 4.25 bs
Nitto 235/45/17 tires
