Tires for a 2011 - Team Camaro Tech
 3Likes
post #1 of 21 (permalink) Old Oct 26th, 16, 02:26 PM Thread Starter
Jennifer
Smile Tires for a 2011
i am trying to figure out how to utilize this camaro chat stuff ?
i'm a girl and i need new tires for my 2011 camaro I am trying to figure out which tires to buy, do i get the BF Goodrich or firestone firehawk, for 235 55 18, can anyone help me out
thank u
jennifer :-)
Camaro Girl Driver is offline
post #2 of 21 (permalink) Old Oct 26th, 16, 02:27 PM Thread Starter
Jennifer
re: Tires for a 2011
help
post #3 of 21 (permalink) Old Oct 26th, 16, 03:25 PM
Originally Posted by Camaro Girl Driver View Post
help
Jenn, I suggest you go to a Discount Tire outlet or Firestone store and they should provide you with all info and tires you need for your car.
Everett#2390 and ctcz28 like this.
TC # 349
zdld17 is offline
post #4 of 21 (permalink) Old Oct 26th, 16, 04:02 PM
Yep, Discount Tire the one for me for the last four sets for my vehicles.
Welcome, Jennifer, enjoy the cruise and enjoy the journey with your Camaro.
post #5 of 21 (permalink) Old Oct 26th, 16, 04:44 PM
scblucam's Avatar
Discount Tire website, punch in your tire size and options will pop up.
Welcome
68 302 M20 - 85 IROC Z
scblucam is offline
post #6 of 21 (permalink) Old Oct 26th, 16, 04:46 PM
Chris
I've purchased all my tires from Discount for nearly 20 years and never gone wrong. If there is any problem, in my experience they stand behind the product and will make it right. If you go to Firestone, I suspect you'll only be able choose from what Firestone makes. At Discount you can select tires from many different manufacturers to fit your needs and budget. If you have a problem, there are way more Discount stores than Firestone. Just make sure of 2 things: (1) get the same size tire that was the original equipment on your car so you don't have any problems with your anti-lock brakes or speedo and (2) make sure they torque them properly which they normally should do so you can actually get the lug nuts off if you have a flat.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #7 of 21 (permalink) Old Oct 27th, 16, 03:52 AM
Kevin
KevinW's Avatar
I get my tires from Sam's club, usually good prices. For a 2011 Camaro LS/LT, it shows tire size 245/55R18, not 235. Sam's has 3 choices, Radial TA is one, Goodyear RS-A and Eagles are the others. Goodyear's show $80 off for a set of 4, but they all have to be special ordered. Luck and welcome!
Kevin
KevinW is offline
post #8 of 21 (permalink) Old Oct 27th, 16, 05:04 AM
mike
I don't think discount tires is on this coast. I used them in Az but was told there are none here. I guess a quick google search would be in order.
bigblockragtop is offline
post #9 of 21 (permalink) Old Oct 27th, 16, 05:48 AM
Gary
MangeMD's Avatar
You can use their online site, Home - Discount Tire Direct . They will ship them to you for free and then you use a local installer (like NTB or such) to install the tires.
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #10 of 21 (permalink) Old Oct 27th, 16, 06:36 AM
Ray
Good advice so far.
Keep in mind that Jersey has plenty of local discount tire shops as well as the usual main stream like Goodyear, Firestone, ETD, Straus, Sears, etc. Any one of them will sell you what your Camaro needs and you won't have to lift a finger.
If you buy online the purchase price is usually better but other cost like mounting, installation, disposal of the old tires, new stems, etc. will all add to the price afterwards.
Your Camaro may have the air monitor system. The sensors will have to be check to see if the battery in them is still good. On a six year old car it's probably a good idea to just replace them. The air monitoring system will then have to be reset so the system "learns" were each air pressure sensor is located. Your manual tells you how to do it, but a good shop will do it for you as part of the install.
satz28 likes this.
'68 rs/SS 350 M-21 posi
numbers matching
rgwiz is offline
post #11 of 21 (permalink) Old Oct 27th, 16, 07:34 AM
Gary
MangeMD's Avatar
If she's not getting a TPMS error, the sensors should still be OK. That being said, this is a prime time to invest in some new ones since the old ones may be on their last legs and they may break when they are changing the tires. You can usually find new ones on Ebay for around 75 bucks or so for four.
MangeMD is offline
post #12 of 21 (permalink) Old Oct 27th, 16, 07:41 AM
Gary
MangeMD's Avatar
2010 GM CHEVY CAMARO RS SS 13581558 TPMS TIRE PRESSURE MONITORING SYSTEM SENSORS | eBay
MangeMD is offline
post #13 of 21 (permalink) Old Oct 27th, 16, 08:12 AM
69-Pace's Avatar
Hey Jennifer - Moved this thread to Wheels and Tires section. Drop back to the Welcome wagon and introduce yourself and your Camaro when you get a chance.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #14 of 21 (permalink) Old Oct 27th, 16, 09:58 AM
Re: Tires for a 2011
The only shop/dealer resetting anything on the vehicles I own is the BMW dealer when they change oil & filter in my M3 annually.
If the shop/store resets devices, be a repeat customer to them.
post #15 of 21 (permalink) Old Oct 27th, 16, 12:48 PM
Doug
Jennifer, If I was buying tires for a Camaro I would be looking at the Nitto Motivo tires. The are a high performance street tire and have a 60,000 mi warranty. You can even order them from Jeg's High Performance online. They are on sale right now with free shipping. Personally the Firestone brand would be the last tire I would put on my car. The Bf Goodrich T/A Radial is a great tire I use to run them on my Monte Carlos years ago. The Nitto brand is for sports cars today. http://www.discounttiredirect.com/di...45&ar=55&rd=18
camarodriver67 is offline
