Front Wheel Back Spacing? - Team Camaro Tech
post #1 of 29 (permalink) Old Dec 1st, 16, 04:46 PM Thread Starter
Mickey
Moonpie's Avatar
It's common knowledge it seems that the most back spacing on the rear wheels one can use is 4.5 inches for max rubber on the first gens. Mine's a 68 with stock leaf spring location and 15 inch rims.
What back spacing do I want for the front wheels? I can't seem to find this anywhere.
Moonpie is offline
post #2 of 29 (permalink) Old Dec 1st, 16, 06:14 PM
Re: Front Wheel Back Spacing?
Front and rear backspacing depends on the wheel width. Diameter is not relevant. What widths are you planning to run front and back?
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 29 (permalink) Old Dec 4th, 16, 07:18 AM Thread Starter
Mickey
Moonpie's Avatar
I would not agree with that. There is only so much back space room before a rim hits the shock mount on the rear. 4 1/2 inches.
Anyone know typical back spacing for the front wheels please?
Moonpie is offline
post #4 of 29 (permalink) Old Dec 4th, 16, 07:27 AM
Vega$69's Avatar
Typical would be the same as the rear for the stock wheels. All four wheels and tires were the same size stock. If you go to a larger diameter wheel you usually go to a lower aspect ratio tire so the overall diameter is the same. Therefore the desired backspace would be the same.
If you go to a wider wheel then ideal BS will change.
Vega$69 is offline
post #5 of 29 (permalink) Old Dec 4th, 16, 07:47 AM Thread Starter
Mickey
Moonpie's Avatar
I'm planning on Torque Thrust D's, 8 or 81/2 on rear with 275/60 or 50's. On the front the tallest tire i can get no more than a standard 78 series wide. I'd love to run my 28x7 Sportsmans but the street use would tear 'em up. So perhaps a 7" or 6" wide rim on the front.
Moonpie is offline
post #6 of 29 (permalink) Old Dec 4th, 16, 08:41 AM
Brent
67Rally's Avatar
I'd say a 225/70/15 would match up well with a 275/60/15. Backspacing on a 15x7 would be around 4-4.5". Just depends on whether you want the wheel more tucked or more pushed out towards the fender.
If you go with a 50 series rear, I'd drop the front to a 60 series to match.
67Rally is offline
post #7 of 29 (permalink) Old Dec 4th, 16, 05:50 PM Thread Starter
Mickey
Moonpie's Avatar
I won't use 60's on the front. Kinda tough on the ball joints and boy am I gonna hear it for that.
Moonpie is offline
post #8 of 29 (permalink) Old Dec 4th, 16, 06:19 PM
Brent, what Is your setup up front if you dont mind my asking? Stock subframe?
3d cad is offline
post #9 of 29 (permalink) Old Dec 5th, 16, 05:02 AM
Saw this on another forum. Best summary I have seen for first gen wheels. I have used backspacing of 5-7/8 with a 10 inch rear wheel and 5.75 backspacing with a 9.5 inch rear wheel.
"Keep your offset as close to +6mm on a first gen as possible and that should center the wheel between the subframe/fender and the frame rail/quarter panel as possible.
Ideal backspacing for maximum clearance is as follows:
17x7 = 4.25"bs
17x8 = 4.75"bs
17x8.5 = 5" bs
17x9 = 5.25"bs
17x9.5 = 5.5" bs
Wheel diameter is irrelevant, it's the same for any 17"/18"/19" wheel."
dhutton is offline
post #10 of 29 (permalink) Old Dec 5th, 16, 08:34 AM
Brent
67Rally's Avatar
17x7 = 4.25"bs
17x8 = 4.75"bs
17x8.5 = 5" bs
17x9 = 5.25"bs
17x9.5 = 5.5" bs
Yeah, that was my post somewhere. Not sure which forum that was on.
67Rally is offline
post #11 of 29 (permalink) Old Dec 5th, 16, 08:38 AM
Brent
67Rally's Avatar
Stock subframe, SpeedTech Upper & Lower control arms, Hotchkis 2" lowering coil springs. Wilwood brakes add .19" to track width. 5" bs on an 18x8 w/ a 245/40/18, and needed a 5mm spacer not to rub on the front subframe. 4.75" would have been perfect.
67Rally is offline
post #12 of 29 (permalink) Old Dec 5th, 16, 09:47 AM
Vega$69's Avatar
The best way is to measure clearance with your existing wheel and tire. Then use one of the online comparison tools to determine wheel/tire combo that will meet you needs.
For example If you have a 6" wheel with 4 1/2" BS and your tire to fender clearance is 2" you know a 7" wheel with the same BS will give you 1" clearance or 1 1/2" if your BS is 5"
When looking at tires look at Section Width along with Tread Width as well as overall diameter.
Vega$69 is offline
post #13 of 29 (permalink) Old Dec 5th, 16, 10:21 AM
Lateral-g.
dhutton is offline
post #14 of 29 (permalink) Old Dec 5th, 16, 12:02 PM
I am under the impression that factory disc hubs have a mounting surface further out than drum hubs. Is that true?
3d cad is offline
post #15 of 29 (permalink) Old Dec 5th, 16, 08:09 PM
Thanks for that info Brent. I need to get back rims soon to fit in the back and its a better deal if I can get all 4. With no front sheet metal that's kind of a scary proposition.
3d cad is offline
