Wheel/tire size for '68 Camaro - Team Camaro Tech
 1Likes
post #1 of 18 (permalink) Old Jan 2nd, 17, 04:11 PM Thread Starter
Brianna
Hey guys, I recently bought wheels and tires for my 1968 Camaro and had issues with the front ones rubbing. I have REV classic Chrome 100 18x9 with 255/45/18 on the rear and 18x8 with 255/45/18 on the front and they rubbed in the front pretty bad. Id like to keep 18x8 in the front, but am considering 17x7. I didn't see 18x7 wheels in that brand. The only modifications are disc breaks to the front. Anyone have any suggestions for wheel/tire size?
Thanks!
Brianna
Brees68 is offline
post #2 of 18 (permalink) Old Jan 2nd, 17, 04:58 PM
Gary
MangeMD's Avatar
Re: Wheel/tire size for '68 Camaro
What is the backspacing on your wheels?
1967 RS Coupe (clone): 406 SBC, Thorley headers, Muncie, Hotchkis suspension, Centerline Matrix 17" wheels with Nitto 555's, Baer brakes, 12 bolt 3.73 posi, RS conversion, Vintage Air, PPG Hot Red. (SOLD)
1968 RS Coupe: Project...Mini-tubbed, Cammed LS 6.0, T56, 12 bolt 3.73 posi, Ridetech 4 link...slowly adding more...
MangeMD is offline
post #3 of 18 (permalink) Old Jan 2nd, 17, 04:59 PM
Some good reading here <-LINK
Brees68 likes this.
68 Camaro~LSx ~all motor
post #4 of 18 (permalink) Old Jan 8th, 17, 10:31 PM Thread Starter
Brianna
The back spacing of the 18x8 wheels I have now is 4 1/2 it's the same for the 17x8. If I go 17x7 it would be 4 inches.
Brees68 is offline
post #5 of 18 (permalink) Old Jan 9th, 17, 04:35 AM
Before you buy new wheels have the front end aligned with -1.0 degrees of camber. Will likely fix your problem.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 18 (permalink) Old Jan 9th, 17, 04:54 AM
George
Gbauer's Avatar
255's in the front is pretty darn wide.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #7 of 18 (permalink) Old Jan 9th, 17, 06:07 AM
Tom Anderson
I think the backspacing is the secret and you need a minimum of 4 1/2 and then 255 back & 235 front IMO
socal_tom is offline
post #8 of 18 (permalink) Old Jan 9th, 17, 06:18 AM
George
Gbauer's Avatar
Even my 225's rub up front. I'm running 7" wheels with 4.02" back spacing so it's possible the 235 would work with 4.5" BS but you might get rubbing on full clock while turning.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #9 of 18 (permalink) Old Jan 9th, 17, 06:59 AM
I am amazed how many people throw away wheels and tires on this site because they won't try negative camber.... It costs nothing to try it....
post #10 of 18 (permalink) Old Jan 9th, 17, 01:20 PM
Brent
67Rally's Avatar
And a 45 series tire on an 18 is very tall up front.
67Rally is offline
post #11 of 18 (permalink) Old Jan 9th, 17, 02:30 PM
Darin
ilikeike's Avatar
I run an 8x18" with 4.875" back space 235/35-18" 3" lowering springs on front no problems. 275/35-18" in back on a 9" wheel.
I had 7x17" wheels 4 " back space and a 245/35-17" and it worked fine.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #12 of 18 (permalink) Old Jan 9th, 17, 09:41 PM
Larry
larryh56's Avatar
You mentioned disc brakes up front. Some kits move the wheels out 1/2"+. You may want to check on that. That will require additional backspacing or a hub that moves the wheel back in. The latter option is what I did with a CPP big brake kit.
Nothing wrong with that but will not be enough from what I have read on here with an 18X8 wheel up front with 255's
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #13 of 18 (permalink) Old Jan 10th, 17, 04:40 AM
Did any of those posts that you read include details of the front end alignment, brake offset and ride height etc? They are meaningless without those details...
post #14 of 18 (permalink) Old Jan 12th, 17, 05:11 PM
Chad
You don't have enough backspace.
I also ran this backspace up front on an 18x8" wheel. Hubs and rotor hats come into play but I would never try an 18x8" wheel with less than 4.75" backspace and highly recommend you do 4.875 minimum. I ran a 245 tire and needed to roll the fender lip and ran a static -1.0* camber. I just kissed the frame with the tire at full lock. If I did my setup over again I would of ran 5" backspace.
TCI Engineering equiped pro touring 1968 Camaro
1stgenCR is offline
post #15 of 18 (permalink) Old Mar 14th, 17, 04:32 PM
How much negative camber can you get with stock control arms? How much will 1 degree of negative camber move in the top of the tire?
Last930 is offline
