Tire Size - 69 Camaro - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 2nd, 17, 06:12 PM Thread Starter
Bob
Wanting to put a 15x10, 5.5 backspacing wheel on rear of my 69. Was told a 275/60/15 tire will work without rubbing. Is this true and could I possible go up to a 295 tire. Have a 12bolt bolt and wheel wells are standard, nothing is cut, Current set-up is 15x8 wheel with 28x11.5x15 ET Street
Ramrodd 69 is offline
post #2 of 7 (permalink) Old Jan 3rd, 17, 02:15 PM
Timmy
Re: Tire Size - 69 Camaro
Hi Bob
I have the L60-15 ( Same as the 275/60R15 shown on Tire Rack Website ) on 15 x 10" Cragar SS w/ 4.25' B.S.
I too have the 12 Bolt and I have about 1/2" free clearance to the Inside Wall of my Tires and Inner Wheel Well surface.
My Tires do Rub the Outer Fender Lips ( They did back in the day ) I have HiJackers too.
You will also have to see if the 15" Wheels with 5.5" B.S. will interfere with your Shock Mounts too ?
I can take a Pic up inside my Inner Wheel Well too if you want.
Timmy
ID:	169818   Click image for larger version
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #3 of 7 (permalink) Old Jan 3rd, 17, 04:45 PM
Chris
Wow, L60-15's, I haven't heard of L60's and HiJackers in years, old school, takes me back. I wish I had a good answer to your question, but unfortunately I can only offer some words of caution. I realize it's a bit apples and oranges, but I'm currently running 17x9" with a 5.50" backspacing (with a 275-40 tire on the rear with a 12 bolt and drums) and I had to use a spacer as they rubbed on the inside. Be careful with the backspace, you might want to use 5.25". I know you're planning on a 15" wheel, so like I said, my input doesn't actually match your intended wheel diameter so this may be of limited help. I did run 255-60-15's on 8" ralley wheels in the past with no problem. I seem to recall a post here somewhere indicating that a 275 is pushing your luck, but you'd have to seach the wheel/tire forum for that info. Good luck.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #4 of 7 (permalink) Old Jan 3rd, 17, 05:05 PM
I think you will want 5.75" backspacing and a 275 tire is the max in my experience. Even then you may have to trim the fender lip at the 10 and 2 o'clock sections. Ride height will play a role too.
If you are going for an old school ride height, ignore everything I wrote...
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 7 (permalink) Old Jan 4th, 17, 04:44 AM
Bruce
Old school look and an old school bumpy ride! What are you going to do with the front tire/wheel and height?
The Camaro Guy is offline
post #6 of 7 (permalink) Old Jan 4th, 17, 05:20 AM
Greg
I have 18x9 Torq Thrust wheels on a 5" back space on my 69. 275/40/18's and they fit without rubbing. I did have to trim some excess qtr panel material from the outer lip. Just basically trimmed it back to the outer wheel house and it's fine now.
My 69 Build thread :
1995 Z28 (sold)
1987 Iroc-Z (sold)
2005 350Z (sold)
gphusker is offline
post #7 of 7 (permalink) Old Jan 4th, 17, 07:28 AM
Vega$69's Avatar
275 is about the max depending on ride height.
Recommended wheel for a 275 is 8-9". I would not put a 275 on a 10" wheel.
Vega$69 is offline
