U111 rambler questions - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 4th, 17, 10:09 AM Thread Starter
Bill
Hello I'm new to this forum and appreciate any help you guys can give me.
I like the U111 wheel and love the price. I have ride tech 2" drop in the front and 2" drop leaf in the back.
Do these wheels fit well? There are forums that suggest a different backspace than the u111s have (I don't remember the numbers right now)
I will also do the ls1 disc brake swap front and rear. Will the rotors push these wheels out too far to fit properly?
I have stock front subframe with ride tech upper control arms. I am buying a custom 9" for the rear so I can adjust the rear location.
I hope that someone has experience with this situation.
Bill
Bill Cameron is offline
post #2 of 8 (permalink) Old Jan 4th, 17, 05:16 PM
Re: U111 rambler questions
Check out the other 69 wheel tire thread running now. The numbers you are forgetting are what makes or breaks your fit.
3d cad is offline
post #3 of 8 (permalink) Old Jan 4th, 17, 08:37 PM Thread Starter
Bill
Ok a lot of the guys are running 5.5 backspace on a 9.5" wheel ( 275/40/18 tire). The u111s are 5.25. this pushes the tire out farther.
Is anyone running this wheel and how does it fit?
Same story with the front wheel. Is anyone running the 18X8" u111 in the front and how does it fit?
It's a 68 so there is less space than a 69
post #4 of 8 (permalink) Old Jan 4th, 17, 08:58 PM
Dana
Check out this video from Motor Trend on youtube:
@14:15 David Freiburger talks about these U111 in 18x9.5 w/ 5.25 in. backspacing and 18x8 w/ 4.50 in. backspacing, and Bridgestone Potenza RE-11 275/40-18s, and 235/40-18s they used on their '67 "Crusher" Camaro.
Raiph is offline
post #5 of 8 (permalink) Old Jan 4th, 17, 09:04 PM Thread Starter
Bill
Yes I saw that but in the video they said they had to raise up the front. He had adjustable front coils. I think it had stock brakes too. On the rear He said he had a spacer and they SHOULD fit a stocker well.
I'm looking for someone that actually has these wheels on their car to tell me how they fit.
Thanks for the input
post #6 of 8 (permalink) Old Feb 5th, 17, 10:32 PM
Jeff Spicoli
GoCamaro27's Avatar
Originally Posted by Raiph View Post
Check out this video from Motor Trend on youtube: Crusher Camaro Complete Suspension Upgrade and Record-Breaking Test Times! – Hot Rod Garage Ep. 32 - YouTube @14:15 David Freiburger talks about these U111 in 18x9.5 w/ 5.25 in. backspacing and 18x8 w/ 4.50 in. backspacing, and Bridgestone Potenza RE-11 275/40-18s, and 235/40-18s they used on their '67 "Crusher" Camaro.
Dude, that's awesome. I hadn't seen this video, and was wondering about the fitment of these wheels as well.
Relax, all right? My dad's a TV repairman, got an ultimate set of tools. I can fix it.
1967 Camaro RS ZL1 427/4 speed
1967 Camaro RS 327 L30 4 speed
1955 Bel Air 4-door, 350/TH700R4
1969 Camaro convertible X11 Indy 500 Pace Car, matching numbers 396/4 speed
1968 Camaro, Grotto Blue project car
1970 Camaro RS
My Mom's 1978 Lincoln Continental Mark V Diamond Jubilee Edition
2000 Rolls Royce Silver Seraph
GoCamaro27 is offline
post #7 of 8 (permalink) Old Feb 6th, 17, 03:47 PM
Ray
I am in the same boat. I am about to make the purchase as you. I have ride tech coil overs and will be ordering the ride tech LCA and drop spindles. I will also have LS brakes from and back. There is a guy on PT with a 71 Camaro that has Rambers with c5 Z06 brakes up front. He DID mention that he had to grind a little of the caliper away to clear the wheel.
camarodude87 is offline
post #8 of 8 (permalink) Old Feb 6th, 17, 03:50 PM
Ray
I am having issues with uploading the picture with the drag and drop option.
Here is the link: http://www.pro-touring.com/threads/1...Camaro-project
