Lock nut issue! - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 9th, 17, 03:40 AM Thread Starter
Bruce
Lock nut issue!
Went to take off my Weld wheels and could not find the lock nut socket. Its been 5 years and cannot remember or find the socket. Any suggestions how to get it off?
The Camaro Guy is offline
post #2 of 9 (permalink) Old Feb 9th, 17, 04:16 AM
Vega$69's Avatar
Re: Lock nut issue!
Grab a cheap socket that fits tight. Hit it onto the lock nut with a hammer and unscrew the lock nut.
http://thegarage.jalopnik.com/how-to-remove-a-locking-lug-nut-without-the-key-1759207243
Vega$69 is offline
post #3 of 9 (permalink) Old Feb 9th, 17, 04:19 AM
Re: Lock nut issue!
X2
'68 RS
VitaminC is offline
post #4 of 9 (permalink) Old Feb 9th, 17, 05:19 AM
Re: Lock nut issue!
If you can find them, there are sockets that have the needle pins inside , that do fit the outer shapes of a nut or wheel lock. But useless if the outer is round and the lock is internally cut.
TC # 349
zdld17 is offline
post #5 of 9 (permalink) Old Feb 9th, 17, 10:59 AM
Re: Lock nut issue!
There are a few good solutions to the problem. If there is a savage yard near you, go there. They have keys to about every locking lug ever created. You can also order master key sets like this one:
Locking Lug Nut Master Key 16 Piece Set - Nails Screws And Fasteners - by Steelman
Gator grip sockets can work if the locking nut does not have a smooth external surface, but I have had less luck with these:
Brand NEW! Endeavor Tool Gator Grip Socket from Brandsport Auto Parts (#GATR-20120MO)
Good luck!
68RS/SS Convertible L48 (350/295 Powerglide)
daverichard is offline
post #6 of 9 (permalink) Old Feb 9th, 17, 11:26 AM
Vega$69's Avatar
Re: Lock nut issue!
Your local tire shop like discount will take them off for free.
Vega$69 is offline
post #7 of 9 (permalink) Old Feb 9th, 17, 01:34 PM
Re: Lock nut issue!
https://www.amazon.com/s/?ie=UTF8&ke...l_8zkne2hlb5_e
But as above, and old socket (12 point) hammered on works most of the time, or you could take to a garage to see if they have the tool to remove them (most do) and give the guy a $20 for lunch to let you use it in the parking lot to remove yours ?
Locks are made to keep the honest man out
68 Camaro~LSx ~all motor
post #8 of 9 (permalink) Old Feb 9th, 17, 03:15 PM
Re: Lock nut issue!
Weld a regular lug nut onto it and spin it off.
BPOS is offline
post #9 of 9 (permalink) Old Feb 10th, 17, 03:53 PM
Doug
Re: Lock nut issue!
I have used these damaged nut removers to remove a locking lugnut. Just make sure you get a size that is large enough. Sears.com
camarodriver67 is offline
