1967 Camaro Rally Wheels Disc Brake Spare - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 4th, 17, 05:55 PM Thread Starter
Hey Guys, my 67 RS Camaro has 4 piston disc brakes with factory 14x6 DG Rally Wheels. My spare is a 14x5 DA. Is the spare factory correct. Thanks, Tom
351just is offline
post #2 of 8 (permalink) Old Apr 4th, 17, 07:16 PM
Roger
rogerh's Avatar
Re: 1967 Camaro Rally Wheels Disc Brake Spare
Looks like the wheels could be correct. Check out this site, the DG and DA are 67 wheels codes.
Camaro Chassis - Suspension, Axle, Brakes, & Wheels
Roger
rogerh is offline
post #3 of 8 (permalink) Old Apr 5th, 17, 01:52 AM
Garth
Check the date codes. My understanding is all 5 wheels were the same from the factory.
Garfields Maro is offline
post #4 of 8 (permalink) Old Apr 5th, 17, 02:47 PM
Garth
Just to clarify, I meant same size. Date codes may be different, but obviously all should be prior to the cars build date.
post #5 of 8 (permalink) Old Apr 5th, 17, 05:10 PM Thread Starter
The DG's are original to the car. They are true 67 with no date code, four total. The 14X5 DA spare also has no date code. My question is there anyone who can verify what the spare should be with the DG option in 67. Perhaps someone with a documented car or an original owner. Thx Tom
67 Camaro RS Convertible 327 4 speed
Original unrestored, documented 35k Numbers Matching
69 Camaro SS Coupe X55 350/300hp 4 speed
Fully Restored Numbers Matching
1969 Camaro Z28 Restored
351just is offline
post #6 of 8 (permalink) Old Apr 5th, 17, 07:38 PM
Russ
The date codes would be on the inside of the wheel whereby you'd have to remove the tire to find it. I too thought the wheels would all be the same from the factory, not a different width/code spare.
Petes L48 is offline
post #7 of 8 (permalink) Old Apr 5th, 17, 10:08 PM
69-Pace's Avatar
If a vehicle did not have the space saver spare option, then all five wheels will be same code.
Date wise that usually meant that all five were from the same batch lot so all within days of each other if not same day in most cases.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 8 (permalink) Old May 2nd, 17, 07:38 PM Thread Starter
Hey Guys, I did procure another 67 DG wheel at English town swap meet. I now have a complete matching set including my spare. Thx for all you help.
351just is offline
